Old 09-10-2014, 04:33 PM   #1
Mega Member
Flakes in Transmission Fluid
Today while routinely checking the fluids in my 2004 Sunseeker 3100 (E450) I noticed some debris on the end of the transmission dip stick. It almost looked like someone had crushed a dried up leaf and sprinkled the residue on it. I wiped it off, inserted and removed the dip stick again and there was a little more. Two more swipes and nothing else seemed to be on the stick. The coach has less than 30,000 miles. So....I am seeking advice and trying to determine if I need to be worried. I looked at a few on line posts that seemed to suggest a little debris was normal...but I have never noticed it before. I have had the RV for less than 2 years. Thanks!
rgarner is offline   Reply With Quote
Old 09-10-2014, 06:36 PM   #2
Average Joe
MrJoe's Avatar
Not being familiar with the newer transmissions, used to be ANY debris in the fluid was trouble. If it were mine, it would be going to a trusted transmission shop for a look-see.
Joe and Karen
2014 Sunseeker 2450sf
Southern Maryland and Beyond!
MrJoe is offline   Reply With Quote
Old 09-10-2014, 06:56 PM   #3
H2oski
X2 on the transmission shop, but you might also try getting an oil sample tested. They would be able to tell you what the contaminate is made of, if any.
Blackstone Labs
Good luck
Wife
2007 Chevy 2500 HD 6.6
2012 Sabre 31RETS
(LA) Lower Alabama
h20ski is offline   Reply With Quote
Old 09-10-2014, 07:11 PM   #4
B47
Blackstone Labs
Good luck
Good advice - military used to call it SOAP for Speckometic (sp) Oil Analysis Program. Operators of jet engines such as aircraft operations,irrigation operators,etc. use it. We would pull aircraft engines that SOAP said were going bad with excessive bearing wear etc. and SOAP results were right on each time.
Just draw a couple ounces of oil out using a plastic tube attached to a collapsible plastic bottle and send it to a lab.
Old 09-10-2014, 07:23 PM   #5
Capt. Mike's Avatar
With any luck, you might get by with a transmission filter and fluid change and not have a serious transmission problem. Good luck
Mike and Yvonne
and Sophie, the little white dog
2017 Columbus 320RSC
2015 Chevy Silverado 2500HD Duramax 4X4
“It's not how old you are, it's how you are old.”Jules Renard
"It's not the years...it's the mileage." - Indiana Jones
Capt. Mike is offline   Reply With Quote
Old 09-11-2014, 05:50 AM   #6
fonzie's Avatar
Do you have the V10 engine in your Sunseeker? If yes, look at the automatic transmission filling tube bracket where it is attached to the exhaust header and see if the tube is rusted out.
PS: the V8 might have same problem
Fonzie
Old 09-11-2014, 08:47 AM   #7
Mega Member
I do have the V10. I will look....thanks.
Old 09-11-2014, 12:06 PM   #8
Automatic transmissions have bands and clutches that are faced with non-metallic material. If the material is not metallic then it is probably "bits" of this material.
The most typical failure, if you have a lock-up torque converter, is the the clutches in the converter. Next would be the bands which will flake off material as they wear.
It would be wise to drop the transmission pan and take a look - Band or clutch wear can sometimes be observed once the pan is off.
cadman99 is offline   Reply With Quote
Old 09-12-2014, 03:06 PM   #9
fonzie's Avatar
I changed my auto transmission filler tube today, took about 1/2 hour, it was rusted through in two locations.......cost of new tube $40 (CAN) at Ford dealership.
Fonzie
Old 09-13-2014, 12:47 AM   #10
Incheon, S. Korea
BigBaron's Avatar
Blackstone Labs
Good luck
X3
Me, Julie, Lil' Barry, Faith, and OSDs, Fang and Treaty
2003 Hyundai Starex (H1), 2012 Coachmen Clipper 126
I don't know when we'll be able to go camping again...
BigBaron is offline   Reply With Quote
