Old 01-22-2011, 12:09 PM   #1
Flat Tire
Just bought my first TT - a 23' Flagstaff and I have a question.
As I was extending my leveling jacks I notices a warning decal that says "do not use leveling jacks to lift tires off of ground".
My question is, if I get a flat, how do I jack up the trailer?
Thanks for responding!
Epat is offline   Reply With Quote
Old 01-22-2011, 12:58 PM   #2
Send a message via Skype™ to scubieman
Use your tow vehicles jack. The one if you have flat tire on your truck or van or car.
2009 Dodge Ram Mega Cab 2500 6.7 cummins
2011 Forest River Cherokee 28BHKS
scubieman is offline   Reply With Quote
Old 01-22-2011, 01:32 PM   #3
Herk7769's Avatar
In my 5th wheel the rear stabilizers are rated for 2000 pounds. If you deploy your stabilizers and then try to do a final level by lifting the front of the camper with the landing gear rated at 6000 pounds you will crush the rear stabilizers. Don't ask how I know.
Name:	Last Shots 038.jpg
HAM CALLSIGN - KC3FFW
Old 01-22-2011, 01:34 PM   #4
As they say learn from others mistakes.
Old 01-22-2011, 01:59 PM   #5
sherdep's Avatar
the sad part is some of us have to learn on our own even after being forewarned LOL
You could also carry a bottle jack or floor jack like I do in my truck Tool box and have a flat piece of wood to lay the jack on as well to change the tire
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
Old 01-22-2011, 03:22 PM   #6
I carry this with me, some people don't like them because it takes two people one to back up or move forward and the second person needs to tell you when to stop. I have used it one time and that was in my driveway when i had to replace an axle on the camper.
Old 01-22-2011, 06:42 PM   #7
Hipshot's Avatar
I have not had a flat on the TT. But, just to see if I could I made a ramp of the lego leveling blocks and pulled one tire up on it, the tire on the other axle was raised off the ground. It took a stack of blocks 5 thick to do this. A tire could be changed using this method. Your TV jack would also work. I also carry a bottle jack.
2010 Rockwood 2604SS
2008 Silverado 1500 LTZ 4X4
Great Wife and Idiot Yorkie
True Friends are like diamonds, precious and rare.
False ones like autumn leaves found everywhere
Hipshot is offline   Reply With Quote
Old 01-22-2011, 07:40 PM   #8
jimh's Avatar
the first thing i looked for was the jack and tire tool. they didn't supply one. dealer said use road service.... i bought a jack and a tire tool and keep it in the trailer. the jack is rated 6 tons (i don't know if it will do it).
before u go anywhere, check and make sure u can get the lug nuts off. mine had those nice decrotave ones on it and my wrench was either a little too big or a little too small. the lug nuts have all been replaced. ur socket should be capable of going all the way to the bottom. the nut inside is a standard size (1/2" deep?). the decrotive part gives a false sense of security.
jimh is offline   Reply With Quote
Old 01-22-2011, 07:51 PM   #9
Herk7769's Avatar
I carry a 6 ton bottle jack; two 6 ton jack stands; and two wood 12x12 for a jack stand pads.
The only time I needed to change a flat was on asphalt and without the wood pads the jack stands would have sunk into the blacktop.
6 tons is 12,000 pounds and is plenty for (worst case 1/2 of a 16,000 pound camper).
Remember to jack on the FRAME and support the axles with the jack stands to change the tire. If the seal on the bottle jack should blow, the only thing between you and your maker will be those jack stands.
Oh, and PS: Break the torque on the lug nuts BEFORE you jack up the wheels. Trying to do this with the tire "in the air" is frustrating (wheel spins) and dangerous (you could rock the camper off the jack).
Torque to proper specs once the mounted tire is back on the ground for the same reasons.
Old 01-22-2011, 08:59 PM   #10
sherdep's Avatar
I am a firm believer in jack stands - sometimes changing flats on the side of the road do not permit the use a jack stand though.
I like the idea of driving one wheel on to the 5 block and changing the tire that way - the only down fall I see to that is if the blocks sink in the dirt while changing it you may have an issue there.
Another idea that might work as well is to use a Hi Lift jack with the piece that lets you lift it by the rim and support the axle with a jack stand and then bring back down to change the tire - this would be a last resort if all else fails.
