Old 04-03-2012, 09:24 AM   #1
Floor under slide
Does anyone know how to bring the lower edge of the slide on the inside up a couple of inches so the floor of the main body can be replaced? I really don't want to remove the slide or pay for a shop to do it. Thank you.
gemert is offline   Reply With Quote
Old 04-03-2012, 10:02 AM   #2
Triguy's Avatar
I've never done it but it might help others if you told us what trailer you have - year, make, and model - and if its an electric or hydraulic mechanism.
By the way - Welcome!!
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 04-03-2012, 12:27 PM   #3
99 flagstaff RBS25. I think its hydrolic but not sure. I was hoping for some kind of adjustment that would adjust it up a couple of inches. Thanks for advise.
Old 04-03-2012, 01:20 PM   #4
Triguy's Avatar
Attached is a manual for a Lippert hydraulic slide mechanism that could give you ideas on adjustments or even removal. I do not know if your slideout mechanism is a Lippert and, if not, then you might find out the manufacturer and contact them for ideas.
Here's some past threads that address slideout removal...
slideout removal
Slide out help
Maybe others who have had to do this can help more.
Scott
2012 Shamrock 233S
Old 04-03-2012, 05:53 PM   #5
Thanks again Scott! That does appear to be the one in my 5th Wheel. It looks like I should be able to raise the height up enough to get a new floor in. I really appreciate your help.
Jerry
Old 04-03-2012, 06:34 PM   #6
Triguy's Avatar
You're welcome. Good luck and let us know how it goes. Pictures are always appreciated
Scott
2012 Shamrock 233S
