Old 07-13-2015, 08:57 PM   #1
daydreaming about camping
jeeplj8's Avatar
Ford EBC - trailer disconnect warning
During our last trip my truck started displaying a "TRAILER DISCONNECTED" message. The icon for the trailer in the Ford EBC would blink red. At first nothing seamed wrong, then I got a "TRAILER WIRING FAULT" message and lost trailer brakes. Shutting truck off reset the system, and I went through it again. I have gone through the brake system on the trailer. I show a good ground on ohm meter at all places in the system. The brakes engage and work fine until the message comes up.
If anyone with this system has run down this problem, what did you find?
2013 Coachmen Freedom Express 320BHDS pulled by a 2005 F250 King Ranch CC
A rainy day camping is better than a sunny day at work.
jeeplj8 is offline   Reply With Quote
Old 07-13-2015, 09:02 PM   #2
mikkeeh's Avatar
Could it be something as simple as a loose electrical plug??
mikkeeh is offline   Reply With Quote
Old 07-13-2015, 09:05 PM   #3
jeeplj8's Avatar
I should probably point out that I have gone through the simple stuff, like a loose plug. Plug seats nice and tight.
I replaced the crimp on connectors at the axles with soldered joints as well.
What I am really wondering is how many people with the Ford system were able to actually find a problem..vs it being something wrong with the EBC.
Old 07-13-2015, 09:06 PM   #4
Scubanut's Avatar
My truck displayed that message once. Just the trl disconnect message. I just used some contact cleaner on the trl connection and the truck connection. That seemed to do the trick for me, been over a year since I did that.
2012 F150 FX4 Crew 5.0
2012 Coachman Freedom Express 292BHDS (outdoor Kitchen)
Scubanut is offline   Reply With Quote
Old 07-13-2015, 09:16 PM   #5
2007 WildCat 32QBBS
05CrewDually's Avatar
With an intermittent problem as you describe I'd suspect the contacts in the plug. The only EBC's I heard of going bad don't work at all. You could go to the Ford dealer and using there scanner software (IDS/VCM II) they can test the controller in 2 minutes and tell you if the controller is bad or not.
Again, more than likely it's the plugs.
05CrewDually is offline   Reply With Quote
Old 07-13-2015, 09:19 PM   #6
asquared's Avatar
Only time I ever saw it on my old f250 was a loose connection.
<a href=http://i62.tinypic.com/28rp645.jpg target=_blank>http://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
Old 07-13-2015, 09:36 PM   #7
jeeplj8's Avatar
The plug looks fine...but looks are often deceiving. Is their a particular brand of plug that fits the ford best? I figure I will just replace the entire plug pigtail on the trailer side.
Old 07-13-2015, 10:38 PM   #8
2007 WildCat 32QBBS
I got my eyes on this one for the trailer.
http://www.amazon.com/gp/aw/d/B004BE...64J2H6HJHWN404
If you do change the female plug on the truck, remember it's a plug- and-play with the factory Ford harness.
http://www.amazon.com/gp/aw/d/B0002R...7+trailer+plug
Also make sure the plug terminals are clean where it plugs to the chassis harness.
Old 07-14-2015, 11:44 AM   #9
DKRITTER's Avatar
I had a similar issue on an old utility trailer and when I went to rewire it for another reason I discovered the ground wasn't sufficient on the trailer.
I haul the 16ft utility or the 37ft LaCrosse with no problems now.
DKRITTER is offline   Reply With Quote
Old 07-14-2015, 11:48 AM   #10
jeeplj8's Avatar
I went ahead and ordered the OEM one (it is made by Pollak) and a zinc end for the trailer wiring. Pretty inexpensive, not to much trouble to change those out.
Thanks for the idea.
ford, trailer
