Old 04-20-2012, 03:40 PM   #1
Ford F53 2007 sway bar bushings "JUNK"
OK, how does a chassis with 12,000 mile have no sway bar bushing left on the rear axle?? Anyone else have this problem.
Fourn3833
2008 Georgetown SE TS
2013 Ram 1500 Longhorn in tow
Fourn3833 is offline   Reply With Quote
Old 04-26-2012, 01:00 PM   #2
Dallas Texas
TexasBBQ's Avatar
Are you sure they were there to begin with?
2004 Cardinal 33CKT
2006 Ford SDD F250 CC 4WD
TexasBBQ is offline   Reply With Quote
Old 04-27-2012, 07:55 AM   #3
There is pieces of them there. Looks like someone chewed them up. Ordered new ones, installing this weekend. Bought the poly ones on Ebay
Fourn3833
Old 04-28-2012, 05:11 PM   #4
OK I am attaching pics of them. AWFUL
ID:	12937   Click image for larger version
Fourn3833
Old 05-14-2012, 10:36 PM   #5
Too old to be too smart
SpringerPop's Avatar
The polyurethane bushings are better, anyway, so feel fortunate that you have had the reason and opportunity to change them.
The link ends have a way of going away, too, and are also poly-replaceable.
Pop
SpringerPop is offline   Reply With Quote
Old 05-15-2012, 01:37 AM   #6
we'll keep an eye on them
Fourn3833
Old 05-15-2012, 10:09 AM   #7
You'll know when that happens when the distinctive rattle is heard every time you hit a bump.
They're more difficult to replace, as you may need to take out the old ones with a hydraulic press, but well worth the effort to do.
Pop
2005 Terry 250RKS, perfect for the two of us and the pups.
It recently replaced our Flagstaff 21FB (which we still have)
2000 F-350 7.3L CC/LB 4WD Lariat 3.73's
Old 05-15-2012, 09:45 PM   #8
Dodge Guy's Avatar
Well look at what those bushings are trying to control!!! lots of force being exerted on those rubber bushings. I agree though, they should last longer than 12k miles, but they are 5 years old and are probably dry from sitting.
02 Ford Excursion V-10 4.30 gears 5 Star Tuner Y-pipe mod Hellwig sway bar Rear Airbags
Prodigy and Dual Cam
07 Cherokee 32B
Better to have a bad day of camping than a good day at work!
Dodge Guy is offline   Reply With Quote
