05-27-2014, 07:05 AM
I drilled mine. Most folks do.
A round hole of a reasonable size does not weaken the frame much(if any) at all.
Now a square cut is a different story.
I used the supplied self tapping bolts. If you tap yours and use off the
shelf bolts use hardened as a plain old steel bolt threads will be weaker
and since the frame is thin, there aren't many threads in contact.
Mine has held up well. I removed them a couple weeks ago to repaint
the tongue and they tightened up nicely when re-installed.
Good luck!
Peace!
Dan & Rita D
