Old 06-22-2015, 06:54 AM   #1
muddyrode's Avatar
front jacks on fifth wheel
ok so went out to a county park for 6 days i know that my battery was getting bad (would not hold a charge for very long) and yes i have a disconnect switch problem upon getting ready to go home the front landing gear would not move it tried but not enough juice to make it move
so i was going to resort to the manual crank located the crank then started looking where to put it, on my old fifth wheel there was a hole behind one of the propane tanks but on this one no hole so i started feeling around and found where the crank would fit on the front jacks shaft but there is no hole in the metal side panel to put the crank thru
how crazy is that.
so i had to asked around and found somebody that had jumper cables to hook to my battery so i could hookup.
so I’ll have to drill a hole for that
2016 SANDPIPER 35ROK
2013 Silverado Duramax 3500HD DRW LB
Stop worrying about the potholes in the road and enjoy the journey
muddyrode is offline   Reply With Quote
Old 06-22-2015, 07:08 AM   #2
Oakman's Avatar
Couldn't you get your truck close enough to connect the trailer's pigtail and use the truck battery to raise/lower the landing gear?
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
Old 06-22-2015, 07:41 AM   #3
Ford Idaho's Avatar
No hole for the crank handle?
That is one serious oversight!
Old 06-22-2015, 07:47 AM   #4
B and B's Avatar
Ours doesn't have a hole either but it is just the plastic liner a utility knife would cut easily in the propane tank, have to remove the tank to use the crank.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 06-22-2015, 11:44 AM   #5
muddyrode's Avatar
I got the truck close enough and plug in the pig tail but the battery was so far gone the trailer hook up would not put enough juice to raise the unit.
maybe i should have dissconnected the battery so it was not pulling juice?
Old 06-22-2015, 11:56 AM   #6
Id put in a second battery when you replace the first one. Its only a few $$.
bruane is offline   Reply With Quote
Old 06-22-2015, 03:44 PM   #7
Had the same issue with the front jacks. Loosen the nut & bolt holding the landing gear so it can be moved up or down to line up with the hole that was drilled for the purpose of inserting the crank, if one was drilled in the first place.
btritschler1437 is offline   Reply With Quote
Old 06-23-2015, 05:51 AM   #8
Herk7769's Avatar
Ditto for our Flagstaff. Painless procedure.
HAM CALLSIGN - KC3FFW
Old 06-23-2015, 05:55 AM   #9
davel1971's Avatar
only a few dollars? More like $200 by the time you buy a battery, box, and cables. Unless you got a good source on batteries and want to hook us all up
David & Lynn
Old 06-23-2015, 05:56 AM   #10
B and B's Avatar
I can run my jacks from the truck charge circuit with no battery. I do need the engine running to engage the charge relay though. The fuse for it is 30 amps, never blown it at all.
fifth wheel, jacks, wheel
