Old 08-16-2016, 03:50 PM   #1
Front levelers will not extend
I have a 2013 Cedar Creek CKTS with the LCI auto levelers. I was trying to extend front levers (they are now fully retracted) to hook up to the truck. The back four levelers raise and lower okay in the manual mode but the front ones won't move. When I try to raise front levelers The hydralic motor will run four about 3 to 4 seconds then you here a click and motor stops. Any Ideals what could be the problem?
lakeozarkguy is offline   Reply With Quote
Old 08-17-2016, 09:43 AM   #2
Head Rambler
Sounds like it might be a solenoid not engaging.
You can try tapping on it while trying to operate the rams and see if it's just stuck.
In an emergency you could try swapping out one of the other solenoid coils (NOT the entire solenoid) to see if it would work for you.
Salem 29RKSS Pushing a 2500 Mega-Cab CTD!
Gotta go campin!
