Old 10-04-2016, 02:57 PM   #1
Front Tires tilted inward
We just bought a 2017 Forester RV on an E-450 frame. When we used auto level it raised the front wheels slightly off of the ground and we noticed that the wheels bow inward at the bottom. When lowered to the ground things straighten out and it drives normally.
Is this normal? If so, why does it do this?
highberg is offline   Reply With Quote
Old 10-04-2016, 03:32 PM   #2
alsdas88's Avatar
You are encountering normal suspension travel in a Ford designed vehicle. No need to be alarmed. When traveling down the road and you encounter a road that causes the front end to bounce, the suspension is doing the exact same thing, only you can't see it while driving.
Alan
2012 Ram 3500 DRW Crew Cab, 6.7 HO Cummins
2014 Columbus M-340RK
'69 Chevy C-10, 396BB
alsdas88 is offline   Reply With Quote
Old 10-04-2016, 04:55 PM   #3
Retired JSO's Avatar
Normal suspension action called twin I beam.
https://www.google.com/search?q=ford...pAPsrYnEXWM%3A
Retired JSO is offline   Reply With Quote
tire, tires
