06-13-2019, 10:33 PM
Goodyear Endurance POP Goes the Weasel
WOW,
Sitting in the campground. Under 400 miles on my NEW GOODYEAR ENDURANCE tires. I hear a sound like air escaping from a tire. Low and behold my brand new Goodyear tire is going flat. We have been parked here for 5 days. No idea why the side wall gave way. Thank goodness we were not on the road. Very disappointed. Nearest Discount Tire is 200 miles away.. I thought I did my homework????
2014 Cedar Creek Silverback 31RK
2016 Silverado 3500HD Crew Cab LTZ Duramax 4X4
06-13-2019, 11:07 PM
Originally Posted by Mac549
WOW,
If the sidewall failed, you probably ran it against a curb
Danny & Darlene
2002 Silverado 1500HD
2014 Rockwood 2703WS 'Emerald Pkg'
Days camped 2015=42 2014=48 2013=41 2012=47 2011=18
06-13-2019, 11:12 PM
Interesting ! My neighbor lost one of his Goodyears after a trip two weeks ago. Got a bubble and it burst in his driveway. He had another one mounted before leaving last friday. He said he's going to run them for awhile and see if it was just a fluke.
06-14-2019, 12:08 AM
I could have but if do not recall hitting anything. Why did it take days to pop??
06-14-2019, 07:19 AM
Finally a blown Goodyear Endurance blow out ... hope you have better luck with replacement ...
Frank & Cindy--- (SOB) 5th Wheel ---2019 Ram 3500 Cummins 6.7 SRW 4x4 8' bed--- Payload 4394------Remi & Sage camping pups---TST 507 TPMS ... B&W Patriot 18K---3.73 axle ... Predator 3500---2019 48 days ---2020 28 days Camping
06-14-2019, 07:21 AM
Watching.............
The delayed failure is a built in safety feature. Ha ha ha
FWIW I have all confidence in these tires
2017 Puma 297RLSS
06-14-2019, 12:20 PM
Yes... it will be interesting to get "the rest of the story."
This is the first reported failure I've read other than one who admitted picking up a nail.
Days Camped ☼ '19=118 ☼ '20=116 ☼ '21=123 ☼ '22=134 ☼ '23=118☼ '24=86
06-14-2019, 12:23 PM
I just got back from a two week, 500 mile trip.
As I stopped for gas, I checked the Endurance tires as I usually do...
One rear tire of a tandem pair looked low, and I could hear a slight squeal from it... air leaking out of the metal valve stem.
I went to look at my TPMS and just as I did the alarm went off at 40#...
When I had the tire serviced by replacing the valve stem, the tire man and I surmised that I probably hit something, maybe a pothole that not only bent the valve stem, but also knocked off a wheel weight. The TPMS sensor was not damaged.
I ALSO do not recall hitting anything, but obviously I did... just so happened I found the problem while stopped for gas. I always circle the gas pump islands wide, so I don't think I hit a curb there...
2014 Shamrock 183
06-14-2019, 12:27 PM
- Protect Your Investment
Defend against sidewall scuffs and punctures with Durawall® Technology and a scuff guard.
What good is any tire if you run over or ever scrape a curb . since goodyear advertises the above there should be extra protection . just shows that any tire can go maybe not at the same rate as china bombs but then again the endurance is relatively new so jury is still out . but the way it's pushed on here you would think it's been out for over a decade
06-14-2019, 12:30 PM
That would be a pretty big pothole to reach in a rim and bend a metal stem . so unless your stems stick out past the rim and tire i find that hard to swallow
06-14-2019, 12:35 PM
X2. Seems like it would bend or break the rim, but I am no tire expert.
2017 Puma 297RLSS
06-14-2019, 12:48 PM
also following
06-14-2019, 01:35 PM
Goodyear Endurance
Where are these made? China? More china bomb tires. I wish someone would make an ST tire in the US
Bev and Wynn, Iowa City, Iowa
2018 Rockwood Mini Lite 2511S
2015 Chevrolet 1500 LT, 5.3L, 3.42 gears
06-14-2019, 01:37 PM
MR.M
you seem like a guy that has to see to believe. so I tried to take a picture to prove that the tire guy and I now what I am talking about...
I do recall saying that I had sensors (TST sensors ) on the tires that may account for the extra length you have obviously overlooked...
tough to get a picture but here are two I just took...
I have no other explanation of what would bend a metal stem in the middle of a trip... maybe your interstates are smoother than mine I drive on in OH? And yes I was doing about 62-63 MPH in the slow lane... not nearly as smooth as the left fast lane and the tire stem that failed was on the right where the biggest potholes occur.
2014 Shamrock 183
06-14-2019, 01:42 PM
They are made in Alabama starting about 2 years ago.
I actually compared the carcass of the take off Westlake tires and the Goodyear tire... the GY was much stiffer when I pushed my weight down on the tire and also much heavier... which gave me confidence to buy them as I felt like they were tougher... I did not buy bullet-proof tires... but I believe they are better tires.
Go to a GY dealer and prove it to yourself!
2014 Shamrock 183
06-14-2019, 01:48 PM
Only hearing of 3 bad ones so far. Not a bad record in 2 years. The bent valve does not count, no tire failure there.
2022 Montana 3855 BR
2019 F350 6.7 4X4 LB Dually
Edgewater 205 EX 150 Yamaha
06-14-2019, 01:55 PM
I'll stick with my Provider F835 ST235/85 R16, load range G, 14 ply rating.
2016 F350 CC Dually Powerstroke 4x4
2014 Cedar Creek 34RLSA w/Level Up
2007 HD Ultra Classic 103
USS Pyro AE-24 WestPac MM2 '71-'75
06-14-2019, 01:58 PM
Always Learning
Dang America Bomb Tires!
(sarcasm)
06-14-2019, 02:00 PM
Always Learning
I found this on a truck tire one day. I never did figure out WTF I did to cause it.
06-14-2019, 02:07 PM
To the OP, do you have any pictures?
2018 Rockwood GeoPro 19FBS
2016 Chevy Silverado 1500 4x4
