04-27-2017, 06:01 PM
Goodyear Endurance tires installed - with trailer lift pictures
2012 Rockwood Ultra-Lite 2701SS, Goodyear Endurance LRD, ProPride 3P 1400 hitch
2013 F-150 FX4 7700# GVWR SuperCrew 3.5L EcoBoost 157" WB Max Tow 3.73:1
John, Dawn and Emily... and Bella the camping kitty
visit our website at www.restcure.ca
04-27-2017, 06:34 PM
Good, now you are also set if you need to change a flat away from home.......
Fonzie
04-27-2017, 06:54 PM
I put on a full set of Endurance tires last week. Replaced two year old Marathons with just over 2k miles on them. Where I park my camper on the side of my house it's slightly sloped. When I jacked up the first side, the camper shifted a tiny bit so I took just one side at a time to the tire shop. The only thing I'm looking for out of these tires is peace of mind. Larry G.
2021 Silverado RST Z71 4x4 6.2L
2021 Flagstaff Micro Lite 25FKS
USMC (Retired) '70-91
04-28-2017, 08:51 AM
Yes we are... doubly so. We have the trailer aid but I think I will also add the bottle jack to my set of traveling tools.
Yours are the same size as mine. Tire buddies!
I'm looking forward to towing with these.
04-28-2017, 09:19 AM
Those are fine looking tires.
2011 Flagstaff 831FKBSS
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
04-28-2017, 09:48 AM
Kinda funny.. where else can you get a bunch of guys(mostly) to show pics of tires and be proud. Even funnier is that I am a little jealous cause I still have Castle Rock and I want something else, even funnier is one has to actually USE the tires to be worried about them.
2017 Puma 297RLSS
04-28-2017, 10:13 AM
I installed a set of the Goodyear Endurance ST205/75-R14 D yesterday on mine. Did it one side at a time. Bought the metal valve stems and found out they couldn't fit the Lionshead Lynx aluminum wheels because the valve stem seat is counterbored into the casting. The place that installed them, put in a high pressure rubber one, short but with metal stem and indicated they were good to 85 psi. Something to be said for the steel rims over the looks of the alloy rims. Like others have said the D tires pick up 280lbs load capacity over the Constancy that it came with. What's a little piece of mind worth?
2016 Flagstaff 27VRL Emerald
14K Equalizer
2020 Silverado 2500HD CC 4X4 6.6L gas 3.73
04-28-2017, 10:32 AM
Too old to be too smart
Jeff, If you really want metal stems with your counter-bored stem holes, look into the Xtra Seal #17-428 stems. They are made for this situation.
Pop
Terry 250RKS, perfect for the two of us and the pups.
2000 F-350 7.3L CC/LB 4WD Lariat 3.73's
04-28-2017, 01:48 PM
Pop
X2. You beat me to it.
Good to see you on the forum, Pop.
04-28-2017, 02:12 PM
Don't post much, but read a LOT!
Local SoCal Springer show tomorrow. I'll be MC'ing the rescue parade.
Pop
04-28-2017, 03:04 PM
we are getting ours installed tomorrow.
04-28-2017, 04:28 PM
I use a similar bottle jack to lift my 8315SS trailer. I carry a piece of 1-1/2 inch square heavy wall tubing 8 inches long, to put between the jack and the frame to distribute the weight.
John U
2007 Rockwood 8315SS Sold 11/19
2014 Silverado 2500HD 6.0L Sold 11/19
Back on the road 10/20
2010 Born Free 22RSK
04-28-2017, 06:14 PM
Pop
No hijack here,,,, Springerpop that is SO great! Wish we could be there!!!
04-28-2017, 08:30 PM
I will have to check all my pressure's, but the all metal stems that America's Tire put on for me seemed to fit my aluminum rims seemed to fit mine fine. Early 2017 production for the Rialto CA plant.
I would not worry about the heavy rubber ones, EXCEPT, I was worried could be damaged by the added weight of my TPMS. Though I have to admit they ran a season and a half on those metal stems with rubber bases.
Tom48
In Sunny So Cal /w
Now in 2005 Holiday Rambler Ambassador DP and The Hot Air Balloon RESTLESS
NO MORE Tricked out
2017 Sandstorm 250 T.H.
04-29-2017, 11:46 AM
Can anyone advise if the Turnpike 225.75R 15 E can be mounted on the 8289 WS aluminum wheels? Is changing the valve crucial for 15 more psi?
04-30-2017, 04:38 PM
Crucial? I don't know, but there are certainly a LOT of tire professionals and manufacturers that think it is.
I'd guess that you have never had a stem failure. From past experience I know they happen.
Valve stems are duck-soup-simple to change when mounting new tires, and the expense is minimal, so I can't see why one wouldn't go with the "common wisdom".
Of course, one could simply roll the dice and let us know how it comes out.
Pop
05-01-2017, 03:52 AM
Always change your valve stems when you buy new tires, you would also need high pressure stems if you are changing from the C rated your trailer came with, I have the same model
Coachmen M/H
Concord
2018 / 300 DSC
05-01-2017, 04:45 AM
Does buying tires that were just put on the market, without any long term real world reliability info/data available, really give you "peace of mind"?
Personally based on issues I have had in the past with Goodyear tires on my trucks I would be skeptical. Made is USA does nothing for me. These junk RVs are also made in the USA.
They are competitivly/reasonably priced at Tirerack.
Time will tell I guess.
05-01-2017, 08:48 AM
Not necessarily. But a step up from the barely adequate Load Range C tires that my trailer came with does.
I guess it will.
