I normally run 110 per tire on Cedar Creek 32RL but I think I'm getting a little bounce, one of the curtains fell the other day, it was no fun to put back up. Another curtain fell last year and factory said it was weak brackets. I'm thinking 100 psi in tires, I don't know. On the road to Alaska
I run 100 psi in mine but have done as low as 90, too. Won't be a problem at all as long as your weight isn't that high. Reducing pressure reduces load carrying capacity. But going to 100 psi isn't too bad.
goodyear has a tire inflation chart online. here is there g614 max load per tire (single tire, not duals). I printed the chart and have it posted inside the trailer
110psi = 3750lbs
100psi = 3550lbs
90psi = 3300lbs
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
