06-09-2016, 05:34 AM
#81
If you run more than 10 PSI over the required pressure for the actual load on the tire, won't you get uneven tire wear due to the overpressure?
In order to keep all the tread face in contact with the road, the recommended tire pressure for the load is, well, recommended; No?
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
06-09-2016, 05:36 AM
#82
I have been told on more than one occasion that road hazard insurance is not available on ST tires. Just sayin'
06-09-2016, 07:21 AM
#83
I'm 15 over load rating and mine are wearing pretty good.
2010 F250 5.4L 3.73
2011 Flagstaff 831FKBSS
Equal-i-zer 4pt 12K
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
06-09-2016, 07:28 AM
#84
Sugar, if that 11K is fiver weight probably only about 9K on your axles.
2010 F250 5.4L 3.73
Equal-i-zer 4pt 12K
06-09-2016, 07:50 AM
#85
Yep 11k is fiver weight. I'm hoping FR will help me out on this seeing they put old ass rubber on my new trailer.
2016 Wildcat 312BHX
2015 Silverado 3500HD
06-09-2016, 10:52 AM
#86
Got it on my Maxxis from Discountdirect.
George Scott
2015 Salem Hemisphere Lite 272RLIS
2006 Heartland BH 3400/Summer Home
2021 Sabre 37FBT
06-09-2016, 11:30 AM
#87
Left Coast
Got it on Carlisle's from Discount tire also
06-09-2016, 06:24 PM
#88
Commercial Member
Running +10 psi over what is needed to carry the load on a high pressure tire (more than 79 psi) is not going to generate significant if any irregular wear. The irregular wear examples you show are more from the bias tire rather than radial tire days.
However lets say the weight indicates 70 psi is needed for the load. When you run down the road the hot pressure will increase because of the extra flexing of the tire due to it being heavily loaded.
Now suppose you run +10% (my suggestion) + round up to 80. The tire will deflect less so it will generate less heat so the hot pressure will not increase as much so part of the +10% is offset by less pressure growth due to less flexing.
Another item with TT usage is that it is very unusual for tires to wear out in the nominal 3 year life of a TT tire so a little more center wear, if it occurs, is not going to be a meaningful issue.
Given the choice I would prefer a tire removal at 4 years due to center wear rather than a tire removal at 3 years due to tread separation.
Inflation in the table is the indicated minimum inflation not necessarily the best compromise between wear and durability.
.Write a blog on RV tire application RV Tire Safety. 48 years experience as tire design & forensic engineer. My RV Freelander 23QB on Chevy 4500 chassis. Giving seminars on RV Tire applications (not selling)@ FMCA Conventions. Mar 20-22 Tucson AZ
06-09-2016, 07:10 PM
#89
I stopped at my Discount tire today after work to get more info. They do offer road hazard on ST trailer tires. Bad news is the Carlisle HD I was contemplating are not in production yet.
I also spoke with Simple tire today and they cannot get Sailun in 235/80/16 but do have the 235/85/16. I have room for these and Simple tire was really great to deal with. DT is also willing to mount them.
Tireman9, if you see this my Hi Spec rims are stamped at 3460# Will these rims handle the 110 psi of the Sailun? I really wanted the 80's to keep my existing tires at least as a spare. The search continues.
2016 Wildcat 312BHX
06-09-2016, 07:26 PM
#90
Check these out. Haven't ever heard anything negative on them. I replaced my Westlakes after 10,000 miles and have had these on for 5000 miles. They get good reviews from folks on the forum. I got mine at discount tire.
Trailer, M8008 ST RadialÂ*
2013 Ford F-350 SD Diesel, 4X4, Crew Cab, Lariat
Sabre 2014 32RCTS, Pullrite Superglide 2900 18K
06-10-2016, 03:49 PM
#91
Commercial Member
As I understand this it is the load that is the real concern for wheels.
06-15-2016, 06:27 PM
#92
My trailer came with LRC trail express tires rated at 2050 per tire. My trailer unloaded has 7500 on the wheels. Not much margin there
My Maxxis LRD are 2540 per wheel
I towed the trailer 110 miles last weekend. Ambient temp was 86 and I only saw 90 on the Tpms
06-15-2016, 06:31 PM
#93
Georgia Rally Coordinator
I had Goodyear on a lot of trailer's and I stand by them. I have on my new camper and they have been flawless. Later RJD
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
06-15-2016, 06:42 PM
#94
tires
I replaced a full set of blowouts with Maxxis M8008 and haven't looked back. I couldn't ask for a better tire. Just returned from a 2,000+ mile through the mountains and they felt great, All temps and pressures were stable on the TST 507 system. IMHE, I highly recommend them.
Aviator Wright Flyer #1919
Army Pathfinder Vietnam, 3 tours
DAV, MOPH, VFW, NRA, 1stCav. ABN
