Okay, lets think about how our trailers are normally supported;...on a tire/wheel which is bolted to a hub, which is supported by bearings at the very end of the axle which is attached to the frame at two locations equal distance from said axle. Logic would suggest that using a jack placed underneath the spring hanger is equivalent to a tire/wheel/hub The manufacturer places the "don't jack under the axle" restriction because some guy sticks a bottle jack 3' inboard of the hub and attempts to jack the trailer up. Any first year engineering student, (and a lot of 8th graders) can deduce that this is an unwise decision, which will probably end with a bent axle. As long as the jack is placed at the location of the axle hanger U bolts, there is no difference than an axle being held up by a tire/wheel. I do use an appropriately sized block of wood between the jack and axle. If, for whatever reason, I cannot jack at this location, then place a 2' length of 4x4 between the bottle jack and the frame. Sometimes we have to be a little creative, but always consider the range of possibilities before lifting 3000 lbs +/- with a bottle jack.
2016 Ford F-350 Lariat CC, 4x4 SRW. B&W turnover with extender. 2015 CC Silverback 29RE, fitted with Reese Goose Box. Amateur Extra Class K5TS, 2016 nights camped 16
