Old 01-25-2012, 07:42 PM   #11
Iggy's Avatar
Originally Posted by m-kram16 View Post
I have been a mechanic all my life and if you have a leak out of a seal than the contamination can get in the hub. Most parts are warrantyed for 12 mo. I think that you should contact your dealer becouse if you wait till spring the 12 mo may pass. Good luck.
You know I think I will call Forest River tomorrow and see if they will send me 2 new caps. It only happpens with only 2 of the 4 caps.
Old 01-25-2012, 07:52 PM   #12
Ours did the same thing. If you take one off you will see that the lip is bent a little, just enough to let some grease out. I think the press that they use bends them a little. A new cap will fix it. Tap it on with a rubber hammer and a block of wood.
murrayflagstaff is offline   Reply With Quote
Old 01-25-2012, 09:23 PM   #13
Iggy's Avatar
I just sent an email off to my warrantee contact at Forest River and asked about my 2 caps. I told home if they sent them to me I will replace them because I don't have a local dealer for Forest River that is within 100 miles.
Old 01-26-2012, 01:21 AM   #14
Mountainmanbob's Avatar
Hello-Kitty-Duck-Tape
Originally Posted by Iggy View Post
And I thought I was the only one that used duct tape that way.
duct tape
can be bought in six packs
works on everyTHING
even broken legs
I now have no hair
on left leg !!
warning
removal of duct tape from body parts
can be painful
Mountainman
Cute: Hello Kitty Duck Tape!
Target now sells....are you ready for it?....Hello Kitty Duck Tape. Yep, Duck Tape brand duct tape has added the Hello Kitty logo to its product line. Individual rolls can be found in Target stores, and you can also buy a six-pack (for $34.98) at Target.com.
Hello Kitty Duck Tape 6 Pk : Target
Mountainmanbob is offline   Reply With Quote
Old 01-26-2012, 10:13 AM   #15
Triguy's Avatar
Originally Posted by Mountainmanbob View Post
duct tape
works on everyTHING
even broken legs
I now have no hair
on left leg !!
warning
can be painful
Mountainman
My kids would love this!
I can also attest to using duck tape for anything. We use to use it to tape up severe blisters in long races.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 01-28-2012, 05:54 PM   #16
Retired May 2015
Call me old fashioned/old school but although I have EZ Lube axles, I repack the bearings with new seals each year on our Sierra 325RGD. Last season i found the spring shackles almost worn through so I upgraded to a Dexter kit with wet bolts and a new "Y" equalizer. I have the tools and time so do not have to pay the high dealer prices. Worth it to me for an extra margin of confidence. Got rid of the cheap Chinese junk tires and upgraded to Michelin XRV. I'm not going to be on the side of the road if I can help it.
dwcjb is offline   Reply With Quote
Old 01-28-2012, 07:16 PM   #17
Iggy's Avatar
I just checked the Michelin XRV and couldn't find one in my size
225/75/R15
The repacking each year is good if you drive 8-10 thousand miles but for most of us that only happens once or twice after retirement. Glad you found your worn shackles before they broke. No moreleaf spings for me.
Old 01-29-2012, 06:27 AM   #18
Herk7769's Avatar
Iggy,
Contact Al-Ko and they will send you the caps. They sent me 4 for free when I complained about early failure due to cracking.
AL-KO Kober - Products
Or
You can buy them at:
Rubber Plug for EZ-Lube Grease Caps 32640, RG04-010 DCRP
HAM CALLSIGN - KC3FFW
Old 01-29-2012, 10:00 AM   #19
Iggy's Avatar
Originally Posted by herk7769 View Post
Iggy,
Or
As always Lou thank for your comments.
I just sent AL KO a message on their website with my information about the caps falling off. We will see if they respond positively. Sounds like they just got a bad batch of end caps that were not to specs. I did save the web link for the caps just in case I need them.
Old 01-31-2012, 11:52 AM   #20
Iggy's Avatar
Contact Al-Ko and they are sending me a bew set all around.
That was really nice of them.
Iggyc
