Yes, I had the same grease leak problem-------
Had the exact same grease leak problem on my 6000 mile trip to P.E.I.
last September. Just before I left on the trip, I adjusted the bearings, brakes and re-greased the bearings with a hand grease gun. I pumped the "RED" grease in until it began to appear at the grease cup. Removed all the old factory "GREEN" grease. I removed all of the excess grease in the grease cup anticipating grease leakage due to heat and the grease being put in under slight pressure from the grease gun. But on the right front wheel I had the grease leak. When returning from the trip, I contacted AL-KO about the problem. The problem was the grease cup not sealing when tapped into place. I now have four new grease cups from AL-KO.
Common problem, easy to correct with a couple beers, Ahhhh, satisfaction!
Sid & HRH MISSY, SHIH TZU
2019 WILDCAT 28 SGX
2014 F-250 KING RANCH PS 6.7L/SWD/6R140/BFT
DAYS CAMPED 2023 69 DAYS
[SIGPIC][/SI[SIGPIC]
