Old 01-24-2012, 07:50 PM   #1
traveler
reinreb's Avatar
grease drip
I would appreciate some experienced advice on a problem I have with my new RockWood 8315BSS TT. After my first long distance trip 7000 km last summer in some very hot weather, I found this grease leak coming from the hub. Dealer tells me that it was just over packed with grease and to keep an eye on it. After cleaning it up and hitting the road again (300km) it re-occurred. Is this kind of issue seen often or am I having my chain pulled.
2017 Ram 1500 Quad, Rockwood 2509S Mini Light
"We travel initially to lose ourselves; and we travel, next to find ourselves. And we travel, in essence, to become young fools again- to slow time down and get taken in, and fall in love once more."
Pico Iyer
reinreb is offline   Reply With Quote
Old 01-24-2012, 08:33 PM   #2
papap's Avatar
Could be over packed. Also looks like maybe the buddy bearing is not sealing.
2016 Forester 3171DS
Work 28 and 28 around the world.
Camp every chance we get
papap is offline   Reply With Quote
Old 01-24-2012, 08:41 PM   #3
H2oski
X2 on the overpacking of grease, that is if you had greased prior to departure on your trip. I had a similar problem after repacking the wheel bearing on my flagstaff 831 and I had to replace the bearing covers. You can find them at any auto parts store. Have the wheel bearings ever been repacked? I would replace the cap. JMHO
Wife
2007 Chevy 2500 HD 6.6
2012 Sabre 31RETS
(LA) Lower Alabama
h20ski is offline   Reply With Quote
Old 01-24-2012, 09:24 PM   #4
x3 on over packed
2012 Rockwood 8314BSS
2011 Chevy
Camping, Dutch Oven Cooking, and Homebrewing
campdohbrew is offline   Reply With Quote
Old 01-25-2012, 02:20 PM   #5
traveler
reinreb's Avatar
Thanks for the insight. I had never repacked my bearings as this was my first trip and didn't think it would be necessary. All total I have about 9000 KM on the rig this would be about 5600 miles.
1. pardon the dumb question....what is a "buddy bearing"?
2. how often should you repack with grease?
3. Should the axel assembly be pulled and inspected on a regualr basis.
Pico Iyer
Old 01-25-2012, 04:15 PM   #6
Too much grease and the cap need to be tapped in to seat properly.
I have the same issue and it was too much grease but also I put duct tape around the cap to kind of seal the cap where it is pressed into the axle. I did have one that keep falling out and needs to be replaced.
Since that time of my leaks I only give it 2 or 3 pumps of grease every 500 plus mile trip. When you remove the rubber cap it SHOULD NOT be filled to the brim with grease.
Old 01-25-2012, 04:57 PM   #7
papap's Avatar
Bubby Bearing is just the cap. It has a spring in it. so when you pump grease into bearings it holds a small amount to pressure on the grease. This is designed to stop water coming in from the back seals. Only thing bad is if you do not have a good seal on the cap or seal grease leakes out. Looks like that is what is causing your problem.
Old 01-25-2012, 06:19 PM   #8
Mountainmanbob's Avatar
rubber caps that slip over the buddy's
there you go
done that before
my boat has rubber caps that slip over the buddy's
keeps extra grease off the wheels
can be found at most all boat trailer supply stores
I think anyway ??
they help to just keep a little more
of the salt water out
or
in this case
to keep the grease inside a compartment
Mountainman
Mountainmanbob is offline   Reply With Quote
Old 01-25-2012, 06:23 PM   #9
Originally Posted by Mountainmanbob View Post
there you go
done that before
I think anyway ??
or
in this case
Mountainman
And I thought I was the only one that used duct tape that way.
Old 01-25-2012, 06:45 PM   #10
DJ's grandpa
m-kram16's Avatar
I have been a mechanic all my life and if you have a leak out of a seal than the contamination can get in the hub. Most parts are warrantyed for 12 mo. I think that you should contact your dealer becouse if you wait till spring the 12 mo may pass. Good luck.
m-kram16 is offline   Reply With Quote
Old 01-25-2012, 08:42 PM   #11
You know I think I will call Forest River tomorrow and see if they will send me 2 new caps. It only happpens with only 2 of the 4 caps.
Old 01-25-2012, 08:52 PM   #12
Ours did the same thing. If you take one off you will see that the lip is bent a little, just enough to let some grease out. I think the press that they use bends them a little. A new cap will fix it. Tap it on with a rubber hammer and a block of wood.
murrayflagstaff is offline   Reply With Quote
Old 01-25-2012, 10:23 PM   #13
I just sent an email off to my warrantee contact at Forest River and asked about my 2 caps. I told home if they sent them to me I will replace them because I don't have a local dealer for Forest River that is within 100 miles.
Old 01-26-2012, 02:21 AM   #14
Hello-Kitty-Duck-Tape
duct tape
can be bought in six packs
works on everyTHING
even broken legs
I now have no hair
on left leg !!
warning
removal of duct tape from body parts
can be painful
Mountainman
Cute: Hello Kitty Duck Tape!
Target now sells....are you ready for it?....Hello Kitty Duck Tape. Yep, Duck Tape brand duct tape has added the Hello Kitty logo to its product line. Individual rolls can be found in Target stores, and you can also buy a six-pack (for $34.98) at Target.com.
Hello Kitty Duck Tape 6 Pk : Target
Old 01-26-2012, 11:13 AM   #15
Triguy's Avatar
duct tape
works on everyTHING
even broken legs
I now have no hair
on left leg !!
warning
can be painful
Mountainman
My kids would love this!
I can also attest to using duck tape for anything. We use to use it to tape up severe blisters in long races.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 01-28-2012, 06:54 PM   #16
Retired May 2015
Call me old fashioned/old school but although I have EZ Lube axles, I repack the bearings with new seals each year on our Sierra 325RGD. Last season i found the spring shackles almost worn through so I upgraded to a Dexter kit with wet bolts and a new "Y" equalizer. I have the tools and time so do not have to pay the high dealer prices. Worth it to me for an extra margin of confidence. Got rid of the cheap Chinese junk tires and upgraded to Michelin XRV. I'm not going to be on the side of the road if I can help it.
dwcjb is offline   Reply With Quote
Old 01-28-2012, 08:16 PM   #17
I just checked the Michelin XRV and couldn't find one in my size
225/75/R15
The repacking each year is good if you drive 8-10 thousand miles but for most of us that only happens once or twice after retirement. Glad you found your worn shackles before they broke. No moreleaf spings for me.
Old 01-29-2012, 07:27 AM   #18
Herk7769's Avatar
Iggy,
Contact Al-Ko and they will send you the caps. They sent me 4 for free when I complained about early failure due to cracking.
AL-KO Kober - Products
Or
You can buy them at:
Rubber Plug for EZ-Lube Grease Caps 32640, RG04-010 DCRP
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
Old 01-29-2012, 11:00 AM   #19
Originally Posted by herk7769 View Post
Iggy,
Or
As always Lou thank for your comments.
I just sent AL KO a message on their website with my information about the caps falling off. We will see if they respond positively. Sounds like they just got a bad batch of end caps that were not to specs. I did save the web link for the caps just in case I need them.
Old 01-31-2012, 12:52 PM   #20
Contact Al-Ko and they are sending me a bew set all around.
That was really nice of them.
Iggyc
