The zerk fitting is behind the center hub thing. You should notice there is a cap on that. pop the cap off to access the fitting. There may be a rubber cover on the zerk fitting. And maybe not. One of our trailers had the rubber cap, the other did not.
I had an awful time trying to grease the bearings on our 1st trailer. The screw on thingee that fit on the zerk fitting would NOT stay attached. And once it got coated with grease, it was next to impossible to get reattached.
I bought one of these ( the longer one ). Have not tried it yet, but it seems to have good reviews. Also long enough to get deep into that center cover.
https://www.locknlube.com/?gclid=Cjw...oiyxoCSj7w_wcB
Tuckerdog1
2016 RAM 2500 Cummins SLT Lone Star 4X4 LB
2016 Windjammer 3029W Platinum
I'm not an expert. But I play one on the internet.
You live & learn or you don't live long.
If you don't punish your children, life will.
