Old 04-14-2015, 05:07 PM   #1
mlangdn's Avatar
Greasing wheel bearings.
Just wondering which grease to buy for adding to my wheel bearings. I bet I only put ~300 miles on the trailer last year. Didn't go that far out since I was pulling with a barely adequate F150. Now that I have the F250 6.7, I'll probably try to make further journeys.
But for now, I need to do some maintenance.
2014 Coachmen Catalina
243RBS 50th Anniversary
2013 F250 Lariat 6.7 Powerstroke
mlangdn is offline   Reply With Quote
Old 04-14-2015, 05:37 PM   #2
rattleNsmoke's Avatar
High temp wheel bearing grease. It's a great idea that your packing those bearings this season. I've read horror stories about bearings being installed with minimal lube. It's also a great time to adjust your elec brakes.
rattleNsmoke is offline   Reply With Quote
Old 04-14-2015, 05:53 PM   #3
Lucas Red N Tacky. Great stuff.
shoose is offline   Reply With Quote
Old 04-14-2015, 06:00 PM   #4
Just as important as greasing is checking bearing tightness/looseness.
Old 04-14-2015, 07:26 PM   #5
RPAspey's Avatar
Speaking of grease and bearings, should bearings need tightened every year? Normally I have my mechanic check them during the state safety inspection. I checked them when I replaced the suspension and two (same axle) needed tightened by 1 slot in the nut.
Lucas Red and Tacky all the way.
2000 Cherokee 29BH with 6V batteries, LED lights & 400 watts of solar power, flipped axles and raised. 2007 Tundra 5.7L DC-LB with lots of mods. C-co, 8/158th AVN Maint.
RPAspey is offline   Reply With Quote
Old 04-14-2015, 11:05 PM   #6
mlangdn's Avatar
I have leaf springs, so that means I can jack up each wheel by getting as close to the wheel as possible?
Old 04-16-2015, 11:22 AM   #7
Crockett's Avatar
i like under the leaf stack, at the tie plate.
Crockett is offline   Reply With Quote
Old 04-30-2015, 05:01 PM   #8
Wheel Gasket size??
How can I determine the wheel bearing size on my single axle 2015 Coachman Clipper? I assume each bearing has a seal or gasket that should be replaced. I covered 8,500 miles this year, so I know they need to be packed. Thank you.
underwriter is offline   Reply With Quote
Old 04-30-2015, 05:13 PM   #9
Witch Doctor's Avatar
Crawl under the unit there should be a tag that say's who made your axles. Then call them give them the weight like 3000 lb or what ever and tell them you want to buy the bearings and what ever else you need. Or have them give you the # and buy them at Napa they can cross reference them with the manufacturer #'s. I know when I bought bearings and seals I got them directly from AL-KO the manufacturer. You should repack them but I don't think you need to replace them yet. I suggest you use Lukas Tackey Red for grease. It should meet the specks but you can also ask them what speck they recommend.
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 05-01-2015, 12:34 PM   #10
Helmsey's Avatar
Another vote for Red N Tacky
2015 Chevy 3500HD
2013 Sandpiper 365SAQ
Helmsey is offline   Reply With Quote
bearings, wheel
