Ditto on the infrared temp guage. I check my hub temperature every stop.
As far as Bearing Buddies, they were designed for boat trailers to prevent grease loss when exposing hot hubs to water when launching
I see no need for them on travel trailers. There is no substitute for disassembling and visually checking for problems.
That said I would pull the hubs and make sure that the rear seals are not leaking, check the brakes and actuators, bearings and seals, repack with the proper grease reassemble and adjust brakes.
Providing the wheels are greased properly (not necessarily the case from the factory ) there should be no reason to be concerned for a year or so.
2017 Alpine 3401RS,Titan Disc,Morryde SRE 4000, 2016 Ram 3500HD Laramie SRW,LWB,4X4, Aisin transmission
