Old 05-17-2016, 09:04 AM   #1
Domtherrien's Avatar
Greasing. When and how often.
Hi all. Been working on ,in and around vehicles and heavy equipment for the last 18 years but I'm new to the travel trailer scene.
We got ours last year brand new and put maybe at most 1200 kms on it. I'm just wondering how often or at what intervals the bearing should be cleaned and repacked.
I assume I should be good for the better part of the summer. There is a 1500 km trip planned in July and I'll be going over the unit and truck a few weeks prior. Other than that we only have maybe 250 km of travel planned until then.
2011 F-150 Supercrew Ecoboost.
2015 Salem 27 DBud.
Domtherrien is offline   Reply With Quote
Old 05-17-2016, 09:27 AM   #2
I check the play every year when I check and adjust brakes. Inspect and pack bearings by hand every two years. New seals as well. We tow about 5000 miles a year.
Lee and Anne
2016 F250 2WD CC SB XLT 6.2 3.73 3,295 lb payload cap.
2014 Salem Hemisphere 282RK 8k lbs loaded, Equal-i-zer WDH, TST 507 TPMS
2017: 4 nights camped, 12 booked
Teamfour is offline   Reply With Quote
Old 05-17-2016, 09:45 AM   #3
clr
X2 same as team4. I have the flowthru grease system so I grease them each spring for the summer and every two years I pull the wheels and drums check every thing and replace all the old grease. By the way use the type of grease that Dexter axle recommends and you should have no problems. Specific NLGI 2 lithium complex, drop point 215c (419f), with EP, corrosion & Oxidation inhibitors, viscosity indew of 80 minimum. A little harder to find then general grease but well worth it.
Chuck & Sandra
Engineer/Teacher
2010 F350 CC 6.4
2015 Prime Time Sanibel 3601
clr is offline   Reply With Quote
Old 05-17-2016, 09:51 AM   #4
Awesome. Thanks for the advice and point to the right direction gentlemen. Will have look when I get home. Also, I don't have the EZ lube setup.
2015 Salem 27 DBud.
Old 05-17-2016, 10:41 AM   #5
Good to know CLR on the EZ lube axles, I was wondering about that myself! Thank you very much!
Domtherrien I had a trailer I bought new for 14 seasons so I can tell you how to deal with those axles. I pulled the tires/ drums every other season, cleaned, lubed, inspected, adjusted the shoes and put it back together. I never replaced anything and never had a problem. Went through 1 set of tires and had about half tread on the new set when I sold it last fall.
If there is any hint of water infiltration when you pull the wheel, replace the bearings/ races and seal on that wheel. I would also install bearing buddies, you can keep an eye on the seal this way, which you cant see without pulling the wheel. Bearing buddies put pressure on the system, which will keep water from getting in. And, if the bearing buddy loses its pressure, you will have an idea you might have lost a seal, you can pull that wheal and fix it before damage occurs.
First thing I do when I get a trailer is pull the wheels, especially on boats! They are always neglected, granted boats are unique but water is the enemy of bearings.
Steve
Golden CO
2016 Grey Wolf 26RR Limited
92 GMC K2500 454
2006 Honda Rubicon ATV
zuterbru is offline   Reply With Quote
Old 05-17-2016, 11:08 AM   #6
Great info. I plan on popping off the covers soon as I'm home from work.
2015 Salem 27 DBud.
Old 05-17-2016, 12:13 PM   #7
Been trailering 30 years plus. My rule of thumb is 12000KM or every second year...whichever comes first. Gives me a chance to look at the brakes and check all the bearings at the same time. Just did ours and found one magnet wire the wires broken off.
Floyd & Carolyn
2012 F150 S/crew 4X4 6.2L 6Spd Tow Max Firestone airbags. 2011 28RKS Wildcat. Yamaha 3000iseb Gen.
2013 22 nights.2014 57 nights.2015 116 nights
2016. 96 nights 2017 72 nights.
Filterman is offline   Reply With Quote
Old 05-17-2016, 12:16 PM   #8
I have been using Lucas Heavy Duty WB Grease (green) since the trailer was new. I called Lucas tech line last week and they were emphatic not to mix types of week. I was thinking of upgrading to their Red Hi Tack Hi temp grease and they advised against it unless I completely washed all the bearing out with solvent.
Floyd & Carolyn
Old 05-17-2016, 12:20 PM   #9
I have aluminum wheels on my new RV and to get to the EZ Lube grease fittings I have to pull the wheels to remove the chrome cap over the fitting. I guess I need to spin the wheels anyway but my old RV with steel wheels the grease fittings were easier to get to.
2015 Rockwood Roo 23IKSS
2015 GMC Sierra 1500
Archicamper is offline   Reply With Quote
Old 05-17-2016, 12:23 PM   #10
Thanks all for every bit of info tons of help guys. Appreciated
2015 Salem 27 DBud.
