Old 08-04-2016, 10:19 PM   #11
Usually Confused Member
emm-dee's Avatar
The axles are probably 5,200 pound rated. However, the 5,080 rating on the main sticker is due to the D rated tires (2,540 pounds each). FR de-rated the axles to match the tire capacity. Same thing on my TT.
As far as all the numbers, only two of them mean anything real. The maximum trailer weight is 10,945 pounds and the max axle weight is 5,080 each. You will have to go to a CAT scale to get the real operating weight weight for YOUR trailer. Once you have that then subtract that number from 10,945 to find out how much stuff (weight) you can put in the trailer. The CAT scale will give you the actual loaded weight for each axle and it's going to be almost impossible to put enough stuff in the TT to exceed that.
At some point during every day you suddenly realize nothing else productive is going to happen the rest of that day. For me, it usually occurs around 9 am.
Vengeance 25V (the Harley needed a home)
Old 08-04-2016, 10:34 PM   #12
CANADA FROG RALLY 2017
B and B's Avatar
The yellow sticker is incorrect. No way you can hall that much weight, The Inside sticker is correct for the weight of the trailer. Dealer should fix this for you.
B and B
2013 Rockwood 8289 Diamond Edition
GY D's/2.5 inch lift kit/Powerhouse 4 KW EFI Generator
2016 Ford F 350 Lariat Power Stroke Diesel Crew Cab FX4
2008 Golden Falcon 380PA Park Model Model
"Oh Canada,True North Strong and Free!"
B and B is online now   Reply With Quote
Old 08-04-2016, 10:51 PM   #13
emm-dee's Avatar
The yellow sticker doesn't show maximum weight, only the empty weight, which is correct plus or minus a couple hundred pounds. The white sticker is the "legal" thing stating the max weight is 10,945. So, if the yellow sticker says 6,800 (really hard to read) you subtract that # from 10,945 to get 4,145 cargo capacity. The yellow sticker OK. Again, it's hard to read the exact digits but you get the idea.
Old 08-04-2016, 11:55 PM   #14
Airdale's Avatar
Forest River specs for the Wildwood Northwest model #T27DBUD match the specs on your sheet #1. Thus, sheet #2 must be in error and for another model trailer although the model number matches sheet #1, however, the dates on the sheets do not match and sheet #1 is the official date sent to NHTSA. I recommend you send your pictures to FR and let them send you the correct sheet #2 - if they can?
Your real problem in the near futures is tire size. Like a lot of other FR trailers yours has tires that cannot survive very long when you get it full of stuff. You should, as a minimum precaution, go up to the same size in a LRE.
Some trailer manufacturers offer a bumper option for light cargo such as you want to add. Have you asked FR about it?
Here is a picture of an optional bike carrier on another brand trailer. I took the picture at a recent RV show. It was offered as an option.
http://www.irv2.com/photopost/showfull.php?photo=29906
p.s. I see nothing wrong with sheet #1.
USN - RET - PDRL
DOD - RET - Journeyman Aircraft Mechanic
SSA - RET
Airdale is offline   Reply With Quote
Old 08-05-2016, 12:01 AM   #15
emm-dee's Avatar
It probably has the LionsHead Vail Sport tires. Easily replaceable with the Maxxis 8008 E-load.
Old 08-05-2016, 04:14 AM   #16
Mr Havercamp's Avatar
Yes, top sticker...ooops......... by habit I always call the white federal sticker in his post the yellow sticker. On the other trailers we had the federal sticker was always yellow, at least the top section of it. Isn't it supposed to be?
The yellow cargo sticker below it says 583 lbs for water? Either the tank is 70 gallons instead of the advertised 40, or the water is exceptionally heavy as about 15 lbs a gallon.
Mr Havercamp is offline   Reply With Quote
Old 08-05-2016, 03:05 PM   #17
CaptnJohn's Avatar
The bike carrier and tray in your photo is standard on my 5er. It is stamped into it, no label to come off, 200# limit. I have never used mine as that extra 2' +/- behind the bumper would seem prone to dragging.
2016 Keystone Cougar 303RLS
2016 F350 diesel
Edgewater 205 EX 150 Yamaha
Old 08-05-2016, 08:01 PM   #18
eTrailer.com sells a shelf which can be mounted over the propane tanks. However that
adds pounds to your tongue weight so you have to know what your margin of safety is. My MiniLite weighs 4800 pounds. My truck (2010 Toyota Tundra 5.7L with tow package) can tow 11,300 pounds.
Ian Walker is offline   Reply With Quote
