Old 08-29-2015, 09:06 PM   #1
has anybody rezero'd lippert level up?
our coach has the automatic 6 point lippert level up system. it still has a small slant to it after the 'auto level' process has been completed. has anybody performed a rezero (calibration) process to this system? did it work? as I understand the process you must go into manual mode and control the jacks manually until you get the coach levelled as you want it. then you hit a series of buttons to tell the system to set this as the new auto level reference point. it looks like you can do this your self without using a dealer. and who calibrated it initially? the factory or the dealer? do we actually believe it was calibrated properly initially? thanks
CHICKDOE is offline   Reply With Quote
Old 08-29-2015, 11:36 PM   #2
Reset mine. Followed the directions in the manual and it worked fine. Mine is a four point system rather than the six but I would think it would basically be the same. Used a carpenters level inside the camper on the floor to get the camper level set.
Steve and Kim
Southern Illinois
2015 Sanibel Traveler 33RS
2011 F350 SRW Crew Cab
si camper is offline   Reply With Quote
