Old 07-18-2015, 09:31 PM   #31
Who Dares, Wins
doc73's Avatar
Originally Posted by Brother Les View Post
Depends on how heavy your unit is. I have/had a set of car ramps that I use to change my oil and filter on our car..... Had the bright idea to use one ramp to get my camper wheels up in the air.....
Started to pull my unit on the ramp and flattened it the height of an inch
For my unit... Noooo, it will not work
Well that had to be an oh ****! Moment... Then probably some uncontrollable laughing
Sent from my SAMSUNG-SM-G870A using Tapatalk
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is offline   Reply With Quote
Old 07-18-2015, 10:15 PM   #32
There are probably more wrong ways than right ways to elevate an axle to change a tire. When on the side of the interstate and the flat is on the busy side of the road the best way is the quickest way. If I have a ramp I will use it and worry about the loading later. If I can't ramp and must jack the axle that will be the choice. Mostly reducing exposure to risk will be my priority. After arriving at my campground I will consider the proper way to replace the spare.
Under this scenario it will take a couple of scotches to resolve that decision I am sure.
Timtation is offline   Reply With Quote
Old 07-18-2015, 10:16 PM   #33
Brother Les's Avatar
When speaking about three tires on the ground and one 'hanging' in the air. While on Spring Break (this year) I had a bearing/brake/backing plate destruction on the back axle drivers side.... I drove down an Interstate in Spartans burg SC with one axle tow strapped up in the air for Eleven miles (11 Miles). Yes, this was a lot of stress on the remaining tire/wheel/spindle on that side, but I had no choice at the time. The axle specs are 4400 per axle. The Camping World Tech who worked on my unit the next day, ground on the spindle that had became egg shaped and beat on new bearings (also replacing a new hub/backing plate/brakes). The threads on the spindle were messed up and he beat the castle nut on and cotter keyed it with a large key. The tire/wheel looked to be just fine and was put back on. I have driven the unit about 1500 miles since that time and all four tires are the same and NONE seem to have any abnormal wear.
I replaced that bad back axle two weeks ago at my house. I placed boards 4 inches high at the front axle and drove up on them. The back axle tires were still on the ground, but a lot of pressure was taken off of them. I blocked up the frame behind the back axle to hold some weight. I took a jack a lifted one tire off the ground (had to go an inch) and pulled the tire/wheel off. Went to the other side and took that wheel off. With the back axle hanging by itself I was able to take it off easily.
I had talked to Lippert about up grading my axle(s) from a 4400 to a 5200 pound. The spindles on the 4400 "beam" are 'rated' at 3500 pounds. What makes the 4400 rating is that the beam size goes from 2 inch to 3inch. To go to a 'pure' 5200 pound axle rating, I would have change out the brakes/hubs/etc from 10 inches to 12 inch size and the cost would be very high to change out what I already had. To my surprise on reading the rating label on the new axle I just recieved, it said '5200' pound rating.... the 'beam' was still 3 inches and the spindle was still the 3500 bearing size, the 'upgrade' difference from my old axle to the new one was the 3-4 times (massive) the welding size that is holding the spindle to the beam. This axle manufacture date was several days after I ordered it from Lippert, so it was 'made' with 'me' in mind and what I had asked for in beefing the axle up.
Brother Les
Old 07-18-2015, 10:54 PM   #34
Herk, you're totally missing it. Your talking about 5 points in a tandem axle scenario, leaving 3 tires on the ground.
The game changer is when you use one of these "ramps" you're totally supporting the 2 points of load from one side all on 1 point stub axle. So the one stub is supporting both weights which is overloading not only the axle but the tire, and spring with double the weight it normally carries.
Your illustration proves my point. The weight has to go supported some where. When you use the ramp it's all going to the one stub that is on the ramp since the other stub is off the ground.
I've taken Statics and Dynamics, too. Herk is correct. As he said: "Sometimes what seems "logical" on the surface is not so mathematically."
Another example: if you hang a load from two cables that form a "V" you'd think each cable will see 1/2 of the weight of the load, but you'd be wrong. They actually see MORE than 1/2 the weight of the load. And as you spread the cable attachment points apart (i.e., spread the V), the load will increase.
2011 Traverse LT, 3.6L, FWD
tire
