07-16-2015, 08:15 PM
Heavy Duty Tire Ramp!
Members wanted a Pic. With Dimension's (Bottom #1 is 27-1/2) (#2 is 21-1/2) (#3 is 16-1/2) ( #4 is 10-1/2) The Wood Material is (2x10) which actually measures (9-1/8" Wide)! Youroo!! This Ramp is (6-1/2" High)! This is for (Tire Changing/Wheel Bearing/Brake Work) Safe/Easy and No Jacking on Frame or Axles!
07-16-2015, 08:35 PM
Left Coast
Where's the matching stain? Bear naked.....mmmmmm
07-16-2015, 08:46 PM
Mine is self chocking.
07-16-2015, 08:50 PM
Left Coast
Where's the bumper police?????
07-16-2015, 09:36 PM
Location: Jonesboro AR--Home of Arkansas State University and the Red Wolves
Thanks for the pic....getting ready to lift the 5th wheel for the first time to remove tires/wheels for some work....just don't want any mistakes.
Lloyd & Kathy Martin
2018 Forest River Palomino Columbus 383FB
2016 Chevy 3500HD SRW Z71 LTZ 4WD Crew Cab, DuraMax/Allison.
2014-38nights/3500 mi; 2015-66nights/6260 mi;2016-44 nights/6106 mi;2017-65nights/6992 mi;2018-47nights/7376mi;2019-65nights/7825 mi;2020-59nights/4142mi;2021-39nights/3072 mi;2022-59-nights/6149 mi;2023-36nights/3001miles.
07-17-2015, 12:00 AM
2007 WildCat 32QBBS
These "ramps" are a great way to bend an axle out of alignment. Lifting all that weight on one stub axle is definitely overloading the axle tube and leaf spring or torsion. Good way to void those warranties and end up with misalignment.
Your next post will be, Why are my tires wearing uneven?
A bottle jack is your friend.
07-17-2015, 06:26 AM
While I have no engineering data to back it up (though Lippert might), I think supporting a static load on one axle side would be less injurious to the axle than the dynamic loads experienced in a single tire blowout.
Losing a tire and driving a short distance to a safe area should not bend the axle, so I doubt supporting the camper static load while the changing a tire would either.
Additionally, the lifted tire load is not increased as much as you would think since the opposite side two would share the static overload.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
07-17-2015, 06:30 AM
Losing a tire and driving a short distance to a same area should not bend the axle, so I doubt supporting the camper static load while the changing a tire would either.
Agree, plus it's no different than going up curbs, etc going into service stations and other places.
07-17-2015, 06:51 AM
I have (5000+ Post) since I Built and Used this Ramp as well as Many other Members who have also used it! When should this (Uneven Tire Wear) start to show? I am only trying to give our Members a (Safe and Easy) way to Lift their units! Our Frames are (NOT) marked with a (Orange Stripe) for Lifting location as (NASCAR Cars) are! Lifting with a (Bottle Jack) in the improper area will do DAMAGE and Very UNSAFE if Kick out Occurs! Can you Please Supply the Location for the Bottle Jack to ALL Members? Youroo!!
07-17-2015, 07:16 AM
I made a pattern of this design and built one at home, then OC made and installed my bracket to carry it. I will have it with me in Goshen if someone wants to make a pattern, I have used it once and it works great, no jack for me to worry about falling. Then you would have real problems. This is a solid lift and safe, most importantly on the side of a highway....
Coachmen M/H
Concord
2018 / 300 DSC
There are aftermarket products designed to do the same thing, like Camco Trailer Aid, Blaylock EZ Jack, & Hopkins Heavy Duty Chock & Lock. I would think these providers have done their homework on functionality, safety, etc. before marketing these devices. Great idea Youroo & OldCoot; I'll probably copy your designs & make one of my own (unless of course you have patent rights), then I'll make them & not tell anyone.
07-17-2015, 07:20 AM
Tinkerer and Putterer
Oh now you went and did it. I was thinking of buying a set of car ramps and you went and reminded me of the wood pile out back! Now I just need to setup a self chocking groove...
I got the dimensions from the Camco Trailer Aid and just changed a few things. Copy anything you want.
07-17-2015, 07:22 AM
Thanks OldCoot, Ireally did not want to go to jail.
07-17-2015, 07:59 AM
Gotta watch out. The 'Copyright' Police are now riding shotgun along with the Weight Police...
07-17-2015, 08:03 AM
Will a car ramp work?
07-17-2015, 08:11 AM
Only if you write rv ramp on the side.
07-17-2015, 09:19 AM
On the side of the road this ramp is a lot safer than a bottle jack. I can't decide where to put a bottle jack on my triple axle anyway. I'm getting ready to rotate my tires on my triple axle and this ramp will work with easy. Thanks for the ramp idea going to make one soon.
2014 Palomino Columbus 3650TH
435AH 12V VMax Charge Tanks, 520 watt Monocrystilline Solar Array, Morningstar MPPT TS-60 CC,Morningstar Remote,Cotek True Sine Wave Inverter,Cotek Remote Controller,50amp Progressive Hardwire Surge Protector
2015 Dodge 3500 6.7L 4X4
2011 CanAm Commander XT 1000
07-17-2015, 11:34 AM
2007 WildCat 32QBBS
Using the ramp your not just supporting the weight of one axle. You're lifting the weight of both tandems on one axle. It doesn't take a degree to see this.
Losing a tire had nothing to do with this. Again, a flat tire is still supporting it's weight, just now it's on the wheel. Plus the other axle is supporting it's share.
Actually, lifting a tire off the ground by the trailing or leading axle is doubling the load on that one stub axle.
As for proper jacking, place the jack under the spring plate or capture a u - bolt in the jack head and jack it just high enough to lift the tire to be removed.
07-17-2015, 11:43 AM
Will you sign the copies at Nashville this year? Kind of like a book signing...
B and B
