Old 07-16-2015, 08:15 PM   #1
Heavy Duty Tire Ramp!
Members wanted a Pic. With Dimension's (Bottom #1 is 27-1/2) (#2 is 21-1/2) (#3 is 16-1/2) ( #4 is 10-1/2) The Wood Material is (2x10) which actually measures (9-1/8" Wide)! Youroo!! This Ramp is (6-1/2" High)! This is for (Tire Changing/Wheel Bearing/Brake Work) Safe/Easy and No Jacking on Frame or Axles!
Old 07-16-2015, 08:35 PM   #2
Left Coast
Where's the matching stain? Bear naked.....mmmmmm
Old 07-16-2015, 08:46 PM   #3
Mine is self chocking.
ID:	83110   Click image for larger version
Name:	Homemade Tire Changing Ramp.JPG
Old 07-16-2015, 08:50 PM   #4
Left Coast
Where's the bumper police?????
Old 07-16-2015, 09:36 PM   #5
jtownstumpjumper's Avatar
Location: Jonesboro AR--Home of Arkansas State University and the Red Wolves
Thanks for the pic....getting ready to lift the 5th wheel for the first time to remove tires/wheels for some work....just don't want any mistakes.
Lloyd & Kathy & Kit(19 yr old cat)
2018 Forest River Palomino Columbus 383FB
2016 Chevy 3500HD SRW Z71 LTZ 4WD Crew Cab, DuraMax/Allison.
2014 - 38 nights/3500 mi.; 2015 - 66 nights/6260 mi.; 2016 - 44 nights/6106 mi.
2017-65 nights/6992 mi.; 2018-7 nights/1037 miles....9 nights booked
jtownstumpjumper is offline   Reply With Quote
Old 07-17-2015, 12:00 AM   #6
2007 WildCat 32QBBS
05CrewDually's Avatar
These "ramps" are a great way to bend an axle out of alignment. Lifting all that weight on one stub axle is definitely overloading the axle tube and leaf spring or torsion. Good way to void those warranties and end up with misalignment.
Your next post will be, Why are my tires wearing uneven?
A bottle jack is your friend.
05CrewDually is offline   Reply With Quote
Old 07-17-2015, 06:26 AM   #7
Herk7769's Avatar
While I have no engineering data to back it up (though Lippert might), I think supporting a static load on one axle side would be less injurious to the axle than the dynamic loads experienced in a single tire blowout.
Losing a tire and driving a short distance to a safe area should not bend the axle, so I doubt supporting the camper static load while the changing a tire would either.
Additionally, the lifted tire load is not increased as much as you would think since the opposite side two would share the static overload.
HAM CALLSIGN - KC3FFW
Old 07-17-2015, 06:30 AM   #8
Losing a tire and driving a short distance to a same area should not bend the axle, so I doubt supporting the camper static load while the changing a tire would either.
Agree, plus it's no different than going up curbs, etc going into service stations and other places.
Old 07-17-2015, 06:51 AM   #9
I have (5000+ Post) since I Built and Used this Ramp as well as Many other Members who have also used it! When should this (Uneven Tire Wear) start to show? I am only trying to give our Members a (Safe and Easy) way to Lift their units! Our Frames are (NOT) marked with a (Orange Stripe) for Lifting location as (NASCAR Cars) are! Lifting with a (Bottle Jack) in the improper area will do DAMAGE and Very UNSAFE if Kick out Occurs! Can you Please Supply the Location for the Bottle Jack to ALL Members? Youroo!!
Old 07-17-2015, 07:16 AM   #10
Witch Doctor's Avatar
I made a pattern of this design and built one at home, then OC made and installed my bracket to carry it. I will have it with me in Goshen if someone wants to make a pattern, I have used it once and it works great, no jack for me to worry about falling. Then you would have real problems. This is a solid lift and safe, most importantly on the side of a highway....
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Witch Doctor is online now   Reply With Quote
tire
