Old 07-11-2012, 05:52 PM   #41
Dave_Monica's Avatar
Originally Posted by herk7769 View Post
The manual slider bypasses the controller and applies maximum voltage unaffected by the gain setting.
I don't agree Herk. The manual slider delivers the gain setting you've dailed into the unit...how do you calibrate the gain you require if it bypasses it. Both the prodigy P3 and the factory BC in the Ford work this way. Set the gain, fully engage the manual slider a 20 - 25 mph, adjust the gain up or down to have threshold braking (just shy of lock-up).
Dave
Old 07-11-2012, 06:05 PM   #42
Herk7769's Avatar
I will need to dig out the manual for the truck. I don't remember reading the manual that way. I remember the procedure for setting the gain and I don't ever remember using the override to do so. Been wrong before and this could be no different.
BRB.
HAM CALLSIGN - KC3FFW
Old 07-11-2012, 06:06 PM   #43
Dave
My 6 yr old Teshonka works exactly like Herk describes. I set the gain on the little side wheel which works in conjuction with the brake pedal, but if I use the manual slide, I can slide it to max and actually slide the trailer tires at low speeds.
Old 07-11-2012, 06:18 PM   #44
Herk7769's Avatar
Yikes, You guys were right on.
I have been thinking it wrong for a long time.
Once again I have learned something new.
The levers apply full system power ONLY if the gain is set to MAX.
Otherwise they deliver the power represented by the gain set in the window.
Old 07-11-2012, 06:22 PM   #45
Not on my old Teshonka Herk. I can turn the gain down to nothing (no numbers on this antique) and still lock the brakes with the manual slide.
Old 07-11-2012, 06:26 PM   #46
Here's the link to the Prodigy P3 manual...BC brake setting procedure is on pge 5.
http://www.tekonsha.com/content/down...ion/N90195.pdf
I've set the factory BC in our Ford the same way.
Dave
Old 07-11-2012, 08:36 PM   #47
Dave
Thanks Dave, but mine is so old that it has no digital display, just a little indicator light that goes from green to orange to red depending on the gain AND the manual slide position. If I step on the brake pedal it will go to Orange and if I hold the brake pedal in the same position and slide the manual control on over, it will turn Red and apply full brakes on trailer.
Old 07-11-2012, 08:42 PM   #48
Dunnc...you really need to treat yourself to a proportional controller like the Prodigy P3. The difference is night and day in their operation. I switched from an old Reese solid state (?) BC to the P3 and couldn't believe the difference.
Dave
Old 07-11-2012, 08:48 PM   #49
Dave
In what way are they better, being an old coot, I think mine work fine. I had to fiddle with the gain on the new trailer, but once set, I don't mess with the gain, just check the manual when I hook up to see that it will lock the brakes while checking the hitch.
Old 07-15-2012, 04:37 PM   #50
baldy's Avatar
No hurky jurky! Nice and smooth.
baldy is offline   Reply With Quote
brakes
