Old 05-21-2012, 04:04 PM   #21
I have a 2011 RLT 2306 TT. Tandem axel torsion. My right rear tire contacts the wheel tub on TT. The adjustment for the axel connection is only vertical and is in the bottom of the slot. (no adjustment available) This is the only tire making contact as the other three have plenty of clearance. The TT is sitting with the front end down as far as it will go using the tongue jack and this is still the clearance. I have pictures showing the tire in question and the left rear tire that I can pass my hand thru. A hole was created by contact which I covered with rubber, steel, rubber combo. Just wondering if anybody experienced this before. Good idea about a frame shop. Thinking about a riser kit. Thanks
ID:	14233   Click image for larger version
ID:	14234   Click image for larger version
emljr is offline   Reply With Quote
