Old 04-17-2015, 01:55 PM   #21
jmcrae3891's Avatar
The other 2 on the front axle are still good. The company I work for has tire guys so I get a good deal on tires.
I watched them balance them so they are good to go!
2003 Dodge Ram QC 2500 4x4
2005 Nissan Altima
2011 Forest River Lacrosse 301RLS
jmcrae3891 is offline   Reply With Quote
Old 04-18-2015, 09:26 AM   #22
jmcrae3891's Avatar
Nee tires on. Figured out the problem kinda sorta. While putting the new tires on I noticed the front axle is noticeably larger than the rear. According to the specs, they are both rated for 4400 GAWR. Should I try to match the front axle or try to see whats wrong with the rear. Here are the tags off the axles.
The dexter axle is in the rear and is smaller. Should I try to put the larger axle in the rear?Click image for larger version
Name:	ImageUploadedByForest River Forums1429367113.823517.jpg
ID:	74578Click image for larger version
Name:	ImageUploadedByForest River Forums1429367133.386953.jpg
ID:	74579Click image for larger version
Name:	ImageUploadedByForest River Forums1429367152.753470.jpg
2005 Nissan Altima
Old 04-18-2015, 12:16 PM   #23
RPAspey's Avatar
Again, you need a new axle. I'll bet, the previous owner replaced a bent front axle then sold/ traded it in. If I'm right, and I'm pretty sure I am, just replace the bad axle with one the same as the good (larger) one.
2000 Cherokee 29BH with 6V batteries, LED lights & 400 watts of solar power, flipped axles and raised. 2007 Tundra 5.7L DC-LB with lots of mods. C-co, 8/158th AVN Maint.
RPAspey is offline   Reply With Quote
Old 04-18-2015, 02:32 PM   #24
jmcrae3891's Avatar
I misread. The d35 is a 3500lb axle that somehow made its way under my trailer. The dealer will be getting a call monday
2005 Nissan Altima
Old 04-18-2015, 03:21 PM   #25
Crockett's Avatar
i found its a lot of times the rear axle gets the damage. when the front axle hits, it preloads the suspension, being allowed to move upward with the walking beam. then, the rear axle gets hammered with the preloaded suspension.
Crockett is offline   Reply With Quote
Old 04-21-2015, 04:01 PM   #26
OntarioFireFighter's Avatar
Not for nothing - but the 18ish month difference in mfg dates is a dead giveaway the Dexter axle is a replacement...
Guessing? Damaged rear axle was replaced with one that was too light; and it's been squatting, causing the tire wear you see.
OntarioFireFighter is offline   Reply With Quote
Old 04-21-2015, 04:04 PM   #27
jmcrae3891's Avatar
Yup. Exactly right. Ive called twice now waiting for a call back.
2005 Nissan Altima
Old 05-02-2015, 03:06 AM   #28
jmcrae3891's Avatar
Update:
I took my trailer to the dealer Wednesday. An employee tells me as Im pulling in my axle is bent😂. I said thats why its here. So yesterday they call to confirm the axle is too small and was replaced at some point like I told them. Im currently waiting for a call back to see what they are going to do. Either way, no money is coming out of my pocket for their mistake.
I don't even know how they bought this trailer from the previous owner without checking everything out
2005 Nissan Altima
Old 05-13-2015, 07:26 PM   #29
jmcrae3891's Avatar
Update #2. The dealer left me a message saying Lippert has to send the axle to Forest River first??? Then to them. So my camper will be in the shop on the 22nd to start repairs !
2005 Nissan Altima
Old 06-25-2015, 02:25 PM   #30
jmcrae3891's Avatar
Just 2.5 months later an axle. Wow! New axle, leaf springs, u-bolts, etc.
2005 Nissan Altima
tire
