Old 06-16-2015, 01:06 PM   #1
Jerry01's Avatar
How close is too close?
My original tires were Goodyear marathons 235/80/16E. After my issue with them and hearing all the negative posts, I decided to replace them. I bought Michelin XPS RIB 235/85/16E. I didn't really think about the difference in size. They are actually about an inch taller. So with the two side by side, there is now a gap of just over 1 1/2 inches. Before there was about 2 1/2 inches between the tires. Now I'm a little worried. Put my mind at ease and tell me I'm ok😁. Jerry
2005 GMC Sierra 2500HD, Duramax 2WD CC/SB
2013 Cardinal 3030RS full body paint
B&W Companion slider, air bags, EFI Live Custom tuning by So Cal Diesel
Jerry01 is offline   Reply With Quote
Old 06-16-2015, 01:08 PM   #2
Jerry01's Avatar
I keep forgetting to add the pics.
Name:	ImageUploadedByForest River Forums1434478076.803521.jpg
Old 06-16-2015, 01:16 PM   #3
dieselguy's Avatar
You did good to get rid of the MaraBombs ... tragedy would only have been a trip or two away. They serve their purpose for light trailers, but fail miserably on heavier ones. I run Michelin LT's as well with about the same gap ... they haven't rubbed yet even when I checked during a tight parking lot turn.
dieselguy is offline   Reply With Quote
Old 06-16-2015, 01:21 PM   #4
Originally Posted by Jerry01 View Post
My original tires were Goodyear marathons 235/80/16E. After my issue with them and hearing all the negative posts, I decided to replace them. I bought Michelin XPS RIB 235/85/16E. I didn't really think about the difference in size. They are actually about an inch taller. So with the two side by side, there is now a gap of just over 1 1/2 inches. Before there was about 2 1/2 inches between the tires. Now I'm a little worried. Put my mind at ease and tell me I'm ok��. Jerry
If they are only an inch taller and you had 2-1/2" clearance, you should now have 2" clearance. 1" larger diameter is 1/2" larger radius if you are talking about tire to wheel well opening.
Old 06-16-2015, 01:31 PM   #5
I am assuming by his comment he meant between the tires, not tire to wheel well opening. 1/2" on both tires would be the 1" difference.
2016 Flagstaff 23LB
howie70 is offline   Reply With Quote
Old 06-16-2015, 01:39 PM   #6
Timex's Avatar
I doubt an xchock will fit between them!
Probably wouldn't before with the GYs either.
2012 Flagstaff V Lite 30 WRLTS
2005 Dodge Ram 2500 5.7 Mag Hemi 3.72 Rearaxle
Nights camped 2015 = 23
Nights camped 2016 = 25
Nights camped 2017 = 13
Nights camped 2018 = 3
Timex is offline   Reply With Quote
Old 06-16-2015, 02:41 PM   #7
Jerry01's Avatar
Yes but there are two tires. So it would be an inch closer. Jerry
Old 06-16-2015, 02:52 PM   #8
GmanHawaii's Avatar
Attachment 80141
That's how my are with no problems
GmanHawaii is offline   Reply With Quote
Old 06-16-2015, 04:55 PM   #9
I did state when referencing tire to wheel well, not tire to tire.
Old 06-16-2015, 06:34 PM   #10
Jerry01's Avatar
Thanks for all of the replies. So even when so even when making a u turn or backing sharply into a campsite it shouldn't be an issue either? Jerry
