04-11-2016, 05:48 PM
How do I find out what axles I have
Does anyone know what axles are on my trailer or how I can find out? I have a 2013 Evo 28 foot.
04-11-2016, 06:00 PM
The surest way is to crawl under the unit and look at the tag on the axle.
Lee and Anne
2016 F250 2WD CC SB XLT 6.2 3,295 lb payload cap.
2014 Salem Hemisphere 282RK 8k lbs loaded, Equal-i-zer WDH, TST 507 TPMS
2021: 35 nights already booked so far
04-11-2016, 10:44 PM
The tag on the axle is not the official or certified capacity. It is the axle manufacturers load capacity tag. Only the trailer manufacturer has the authority to certify your trailer axles. That certification is found on the federal certification label as each axles GAWR. The value may or may not match the axle manufacturers value but what ever it is its certified and appropriate for your trailer.
A Trailer Tire Poster
04-12-2016, 04:53 AM
OP didn't ask what the certified capacity was. They asked what kind of axles were on the trailer.
Lee and Anne
04-12-2016, 11:38 AM
make sure you take a picture of the label on the axle while you are under there.
04-12-2016, 03:18 PM
Teamfour X2. What I have done is take pictures of those labels as well as the stamping on the backing plates on all four wheel ends. When I did my last bearing pack, I also recorded the inner and outer bearings, race and seal numbers. That way if I'm ever stuck on the road and have to buy parts I can go into pretty much any automotive store and get the parts. Being proactive saves a lot of frustration and headaches after the fact.
Floyd & Carolyn
2012 F150 S/crew 4X4 6.2L 6Spd Tow Max Firestone airbags. 2011 28RKS Wildcat. Yamaha 3000iseb Gen.
2014 57 nights.2015 116 nights .2016 96 nights .2017 72 nights. 2018 157 nights. 2019 52nights.2020/21 118 nights. 2022 115nights
04-12-2016, 05:37 PM
X2! Get under and get those pictures. It will save you a big headache in the future.
2014 Coachmen Brookstone 325RL
2015 Chev Silverado 2500 Diesel.
04-12-2016, 06:03 PM
...as well as the stamping on the backing plates on all four wheel ends. When I did my last bearing pack, I also recorded the inner and outer bearings, race and seal numbers.
Great ideas!
Lee and Anne
04-12-2016, 07:09 PM
CDR USN Ret
But when you go to spec repairs and parts for the axles, brakes, hubs and bearings you want the axle manufacture's info - not the trailer manufacturer's.
2015 XLR415AMP
2011 3500HD Duramax/Allison/90 Gal Aux
2015 HD Limited Low
04-12-2016, 07:17 PM
My go-to guy and Camping Buddy had a trailer rental business for half of his adult life. He told me there was always a set of bearings and races packed and hidden in the trailer so if a customer had a problem on the road and called in they could be sent to any local shop for the fix. Parts in hand. Seems like a good practice to me
