Old 06-17-2012, 06:03 PM   #1
feerobk's Avatar
How hot should bearings run
I have a 2009 flagstaff 26rls and just had the bearings & races replaced & repacked and we took a short trip this weekend so i checked the hubs just by touch and they seemed to hot getting a temp. gun to check next time out how hot should they be?
Bryan & Robin Feero
2009 Flagstaff 26RL
2003 F150XL 4x4 5.4L
Days Camped 2012 = 9
feerobk is offline   Reply With Quote
Old 06-17-2012, 06:32 PM   #2
jd-ford-hd's Avatar
If the hub is too hot to touch, it is too hot, period. It should feel very warm. I am a working man with pretty tough hands and I use the 5 count method. Grab the cast part of the hub, not the dust cap, count to five. If you can't do that it is too hot.
"IF IT AINT GOT A MOTOR, I AINT INTERESTED"
jd-ford-hd is offline   Reply With Quote
Old 06-17-2012, 06:37 PM   #3
Herk7769's Avatar
My hubs are cool to cold to the touch after 5 hours at 65 MPH.
It has been my experience that most RV techs have no idea what an UltraLube hub is. They hand pack the bearings like my great grandpa did when bearings lasted 20,000 miles. Most also overtighten the hub nuts.
Ultra-Lube Axles and Bearings Procedures
104 posts of why that is so.
HAM CALLSIGN - KC3FFW
Old 06-17-2012, 06:39 PM   #4
TURBS's Avatar
Can't always go by that.
What if he was on the brakes pretty heavy just before stopping?
That would heat up the hubs tremendously!
Old 06-17-2012, 06:42 PM   #5
Herk7769's Avatar
I don't think he was worried about hot hubs due to a panic stop.
I have been wrong before though.
Old 06-17-2012, 07:04 PM   #6
feerobk's Avatar
No hard stop before i checked the hub I don't think I could have done a 5 count on one of they all the hubs were what I would call very warm run only less than a hour 55 or less if the hub nuts are to tight will that make them run hot if the nuts are to tight if i back them off a hole should they move when i push and pull on the wheel?
Bryan & Robin Feero
2009 Flagstaff 26RL
Old 06-17-2012, 07:06 PM   #7
DAISY BOYKIN's Avatar
"I have been wrong before"----------
Can't believe HERK said that!
Sid, Lois & HRH MISSY Terrible 2s SHIH TZU
2011 ROCKWOOD 8285 WS
2014 F-250 KING RANCH PS/SD/6R140/BFT
DAYS CAMPED 2018 21 DAYS
DAISY BOYKIN is offline   Reply With Quote
Old 06-17-2012, 07:06 PM   #8
feerobk's Avatar
I meant to say should the hub move if i push pull on the tire
Bryan & Robin Feero
2009 Flagstaff 26RL
Old 06-17-2012, 07:07 PM   #9
Herk7769's Avatar
Here is the procedure for the wheel nuts.
File Type: pdf 0132-bearing-inspection-maintenance.pdf (112.1 KB, 318 views)
File Type: pdf Bearing Repack and Brake adjustment.pdf (549.5 KB, 138 views)
Old 06-17-2012, 07:08 PM   #10
Herk7769's Avatar
Hard to believe, ain't it.
It is the "Pierre the Bridgebuilder" problem.
bearings, led pad
