Old 06-22-2016, 01:05 PM   #1
Commercial Member
How I installed Externion hoses
With just a hub cap I did this.
Pop rivet to side of hub cap.
With Wheel simulators you might find it easier to do this.
Install the retaining 'L" brackets to the face of the center hub.
You may note that I have labeled my TPM sensors. This eliminates the need to re-program the monitor whenever I remove the sensors for any reason.
Unless the end of the stem is damaged or the "O" ring in the stem end of the hose is damaged, hoses do not need to be much more than tight enough so no air is leaking i.e. finger tight (check with soap water spray) plus 1/4 turn is plenty.
Write a blog on RV tire application 40 years experience as tire design engineer. Freelander 23QB on Chevy chassis is my RV. Giving seminars on RV Tire applications (not selling) in Elkhart May 17-19, Allegan MI June 6-9, & Gillette WY July 18-21 RV Tire Safety Blog
Tireman9 is offline   Reply With Quote
led
