Old 03-22-2014, 10:19 PM   #1
How much grease?
I have the Super Lube Lippert hubs on my Sabre and went to grease them today. I followed the procedure for greasing the bearings, which states to pump grease until you see the old grease seeping out at the cap. I never could see where the grease was seeping out, so I stopped after a while because I was afraid of over-greasing and blowing out the rear seal.
How many pumps of grease from a grease gun do most of you pump into the fitting before you see it start to seep out?
2012 Palomino Sabre 32BHTS
2008 GMC Sierra 2500 SLE 4x4 Duramax
clange is offline   Reply With Quote
Old 03-22-2014, 10:32 PM   #2
Experienced Newbie
The first time I greased my hubs, I used more than a full tube of grease between both hubs before I saw any movement near the nipple/zerk. Ever since, I have put a pump or two in before each trip.
Sent from my SGH-M919 using Forest River Forums mobile app
2011 Silverado CC/SB
2014 Cougar 31SQB
mhartzel is offline   Reply With Quote
Old 03-22-2014, 10:45 PM   #3
That makes me feel a lot better...I put about 20 or so shots of grease in each one and quit at that point for fear of causing a problem.
I think that's a great idea to give it 2 or 3 pumps before each trip. I think I'll start doing the same!
Thanks!
Old 03-23-2014, 06:43 AM   #4
Wanna Be Camper
SaskCampers's Avatar
The reason they take so much grease the first time is the bearings are packed the proper way when they are installed and you have that big cavity inside the hub you need to fill with grease before any will start to come out of the front per the instructions.
John & Deb
2011 Flagstaff V-Lite 30WRLS
Days Camped 2016: 3 2017: 0
Old 03-23-2014, 06:54 AM   #5
davel1971's Avatar
be careful with over greasing. Since the grease thins with heat, and is under pressure with greaseable hubs, you could end up greasing your brakes. By the time you see it, the damage is done.
David & Lynn
Old 03-23-2014, 06:55 AM   #6
PhoneDude 8289's Avatar
Greased mine yesterday. 3 month old RV and here is what I found. One wheel took a couple of pumps, two more wheel took four - five pumps and one wheel took 14 pumps. Wheels were taken off the ground one at a time turning them as I pumped the grease in.
Joe & Beverly
2014 Ram CTD, CC, SB
2014 8289WS lifted
PhoneDude 8289 is offline   Reply With Quote
Old 03-23-2014, 07:09 AM   #7
Shouldn't be under pressure unless you are using Bearing Buddys. The EzLube system is non pressure.
Old 03-23-2014, 07:23 AM   #8
davel1971's Avatar
you are correct. I guess I should have been more specific. Just making the point that regardless of what system you use, not to overdo it. While occasional greasing is a must, grease is not "consumed" so greasing to often could be harmful to.
David & Lynn
Old 03-23-2014, 09:48 AM   #9
Wow. I was nowhere near as fortunate. I suppose my hubs are more like SaskCampers said and I need to fill the void between the bearings.
I think I'll probably latch on to my Sabre and drag it down the road a bit to heat up the bearings some and then I'll pump some more grease in and hopefully fill up the empty cavity between the bearings.
Old 03-23-2014, 10:13 AM   #10
acadianbob's Avatar
Yes. Mine took a lot the first time also. I wouldn't assume that the factory always does a good job of greasing. I buddy of mine bought a new Rockwood; assumed all was good; almost immediately burned out a bearing. IMO, it is wise to go out there and grease it right away. After you've done that, it is easy to do a few pumps once in awhile as maintenance. My trailer has 30K on it now. I had the bearings examined and re-packed at 25K. They were perfect.
2018 F250 Lariat 6.2 4X4 w 4.30s, 2018 Wildcat 29RLX
2003 Yamaha FJR1300, Demco Premiere Slider
Red Green coffee mugs
