Old 12-08-2018, 12:02 AM   #1
How to check tire pressure on inside duallies?
How do I check the tire pressure or add air to the inner rear tires of my 2401R MBS? I just bought it new and the 4 outer tires were all close to 20 psi below spec so I am guessing that the other 2 need air also.
RV-MO is offline   Reply With Quote
Old 12-08-2018, 08:47 AM   #2
You will need to get a truckers air gauge and take the time to learn how to use it. Some people add extensions to their duals to make it easier. When I had an RV, I could check the inners with the extended air gauge. I would add a tire pressure monitoring system if I was you.
BarabooBob is offline   Reply With Quote
Old 12-08-2018, 11:26 AM   #3
007matman's Avatar
I bought this one for my F350 Dually.
AstroAI Digital Tire Pressure... https://www.amazon.com/dp/B01NCX3H1G?ref=yo_pop_ma_swf
Works well. It has a straight push-on chuck on one side and the angled on the backside.
007matman is offline   Reply With Quote
check, pressure, tire
