Old 02-10-2012, 09:15 AM   #1
How to replace a faulty power jack switch?
Hey folks, I have a 2011 Windjammer and the power jack switch is giving up on me. It will go down but not up. Is this a do it yourself fix? I hate to have to jack it up manually and tow it 20 miles to the dealer in winter for something this simple, but at the same time I don't want to screw up the power jack.
markvalve is offline   Reply With Quote
Old 02-10-2012, 09:21 AM   #2
Four or five wires. Probably a 5 minute job.
Old 02-10-2012, 09:23 AM   #3
jimh's Avatar
someone else will have to answer that. i would try spraying the switch contacts with WD40 and exercising it. (may be able to spray around the switch and get some on the contacts). i have found this to work on my front exterior light switch. the wd40 dissolves corrosion.
jimh is offline   Reply With Quote
Old 02-10-2012, 09:26 AM   #4
Thanks fella's...How do you get the old switch out?
Old 02-10-2012, 10:53 AM   #5
Are we talking about the power tongue jack, or the power stabilizers ? I replaced the switch on the power tongue jack on my previous trailer - not sure of the brand name but at the time , I found an exploded view drawing on the manufacturers website which helped with change-out.
...VTX-Al
VTX Al is offline   Reply With Quote
Old 02-10-2012, 11:09 AM   #6
It's the power tongue jack at the front of the trailer, not the power stabilizers. Thats a good thought...I'll get the paper work out on it and check the mfg, website. Thanks.
Old 02-10-2012, 11:18 AM   #7
camping
tentcamper1's Avatar
I sent you a PM
2007 Chevy 2500HD CC
2010 V-Lite 30WRLTS
Nights Camped 2011 -64
Nights Camped 2012 -50
"I Live in My Own World, But It's OK. They Know Me"
tentcamper1 is offline   Reply With Quote
Old 02-10-2012, 11:23 AM   #8
leencharlotte's Avatar
Just a thought. When my battery is low mine does this as well. If you are running off battery might want to check this before replacing anything
2011 F-350 SRW Lariat FX4
2014 Sandpiper 365SAQB
leencharlotte is offline   Reply With Quote
Old 02-10-2012, 01:51 PM   #9
DDC
DDC's Avatar
I had problems similar to you I took it of and took it apart only to find out that the magnets in the motor had come un glued, I cleaned it up and used epoxy to re-attach the magnets and it works great , I found that a lot of water was getting in so I sealed it up with caulking I also cut the top off of a plastic gallon container and it slides over the top nicely when it is parked.
DDC is online now   Reply With Quote
