Old 04-21-2016, 05:56 PM   #1
Delco Bobby's Avatar
I bought the TST507 TPMS
Beyond some programming hassles that my limited brain function may have caused I have the following issues. Feed back on these will be appreciated.
I don't know the upper and lower pressures that I should have programmed into the system and also the tire temperature settings. This system seems to come preprogrammed for larger trucks.
I have BF Goodrich tires on a Sunseeker. I didn't see anything on the BF Goodrich web site to help me.
I had to remove the front wheel covers to have clearance for the sensors and I am reluctant to reinstall those wheel covers. So now I have some very nice chrome lug nuts on display. Not bad.
It was a major hassle for me to get the rear sensors on the duels, especially the inner tires. There is now about 5/16 of an inch space between the two stems with the sensors attached. I am concerned that they may touch while underway. I had my valves lined up one behind the other as had been suggested in this forum. Prior to that my inner valve stems were not visible.
The sensors give me a pressure reading that does not agree with my tire pressure gauges. I have one gauge that I have been using reliably since the 70's but it is not suitable to use on duals. I have purchased a few others recently that are all within a couple of pounds of each other but about four or five pounds off from these sensors. One is a Slime and the other two are by Tire Minder, one digital and one analog.
Should I be worried about driving with the stems of the sensors so close together?
Do I really need to use the locking collar?
With the rear stem situation I had to leave off the metal tire stem caps which leaves me uncomfortable.
TIA,
Bobby
2017 Dynamax REV 24RB
2018 Ford F-150
Delco Bobby is offline   Reply With Quote
Old 04-21-2016, 06:16 PM   #2
I can only help here: watch the video online on how to set up the system. If I remember, you want the high pressure limit 5 psi above the recommended pressure found on the sidewall. Low limit 5 psi below. Tire temp is only a high limit - use the TST recommendation.
Lee and Anne
2016 F250 2WD CC SB XLT 6.2 3.73 3,295 lb payload cap.
2014 Salem Hemisphere 282RK 8k lbs loaded, Equal-i-zer WDH, TST 507 TPMS
2018: 10 nights camped, + booked
Teamfour is offline   Reply With Quote
Old 04-21-2016, 06:22 PM   #3
Flybob's Avatar
If you set the tire pressure 5 PSI above the recommended cold pressure, you will have alarms. A normal tire will increase more than 5 lbs from cold to highway temps.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 04-21-2016, 06:33 PM   #4
clr
On my TST507 instructions it said to set the high pressure at 20% above the recommended cold set pressure and the low pressure at 10% below. Just a FYI you must set the low pressure first prior to being able to set the high pressure. This is true if the high pressure is less than 120 PSI if I recall.
Leaving off the caps is not a very good idea. I had one tire guy say some tire vendors claim that the cap holds the pressure in the tire, and if no cap they will not cover the warranty for the tire. Seems odd to me but vendors do require the caps.
clr is offline   Reply With Quote
Old 04-21-2016, 09:55 PM   #5
I intended to watch the video again but forgot to do so.
I will go with the preset high temp reading unless someone tells me otherwise. Although it seems really high.
2018 Ford F-150
Old 04-21-2016, 09:56 PM   #6
Right now I am planning to change my high pressure reading to 10 pounds over my normal. I think if I monitor the temp with use I will have a better idea as to what will avoid unnecessary alarms.
2018 Ford F-150
Old 04-21-2016, 10:00 PM   #7
All that you said makes sense and I will read the instructions for the umpteenth time. Too many concussions takes a toll on the brain functions.
i have heard the same about the metal stem caps since I was a teenager long ago.
2018 Ford F-150
Old 04-22-2016, 11:35 AM   #8
TPS
I have used the system for 2 years now NO problems - as far as temp - I had to call the manufacture, as far as tire pressure - same thing ask manufacture, but there should be a sticker in your home with pressure on it, Also as a last I have all my tires filled with nitrogen - the coach rides smoother and the tire pressure does not rise as much when tires are heated from road friction.
I have a Forest River diesel pusher.
Mike J
emt2361 is offline   Reply With Quote
Old 04-22-2016, 12:19 PM   #9
rsdata's Avatar
You can and will "grow into" the system as you use it you will become aware of the settings and be able to watch the temps and the pressures increase when traveling on the monitor.
Setting something other than defaults as a new user will cause you some grief I think. As you become familiar with the unit you can make changes... nothing will require re installation of the stem monitors, so the hard part is over.
My sensors seem to read 2-3# lower @ 50# then my trusty digital meter, but I now know when they read 47# my gauge will read 49-50#.
Don't make them overly complicated as a new user...
2014 Shamrock 183
2014 RAM 1500 Bighorn Crew Cab, HEMI, 3.21 gears, 8 Spd, 4X4
Old 04-22-2016, 12:28 PM   #10
Left Coast
Also, on the rear duals, the valve stems should be 180 degrees from each other....not in line
