Old 08-10-2012, 08:25 AM   #11
I have replaced several U-bolts over the years and have never seen a factory replacment nut used with Nylock. The factory nuts are usually longer and require a high torque. Youroo!!
Old 08-10-2012, 11:11 AM   #12
RPAspey's Avatar
I got what the local camper repair place uses. their u bolt kits use the same fine thread nuts too. all the u bolts in mine are nylon lockers. since my axles are flipped, the weight is on the axle and the u bolts keep everything in place. I wouldn't think high strength doubly thick nuts would be needed.
2000 Cherokee 29BH with 6V batteries, LED lights & 400 watts of solar power, flipped axles and raised. 2007 Tundra 5.7L DC-LB with lots of mods. C-co, 8/158th AVN Maint.
RPAspey is offline   Reply With Quote
