Old 08-01-2016, 07:37 AM   #31
dcheatwood's Avatar
Dr g. I had rubber valve stems for several trips on my 5th wheel. 15" tires. Worked ok but i began to see wear marks on the wheel itself where the tpms was rubbing from centrifugal force. I have switched to metal now.
2013 Rockwood 8282WS
Reese Revolution Pin, Reese 16K
2008 Tundra Limited Double Cab 5.7L
Air Lift 5000 w/Wireless Air
Old 08-01-2016, 07:40 AM   #32
clr
I would say get the TPMS system and place them on the rubber valves that you have now. Then when you have the time change the valve stems to metal. Metal stems are recommends or required by some due to the weight of the sensor and spinning it at 65 MPH over time may stress and crack the rubber stem, but this normally takes many many miles and much time.
Chuck & Sandra
Engineer/Teacher
2010 F350 CC 6.4
2015 Prime Time Sanibel 3601
clr is offline   Reply With Quote
Old 08-01-2016, 08:23 AM   #33
gectisme's Avatar
New TPMS at the start of this trip, so far 4200 miles with rubber valve stems, non-flow through sensors. I didn't have time to change to metal stems before leaving on this trip. No noticeable indications of anything wearing or rubbing so far. Now I guess I will change to metal stems when I need new tires, unless I see something that makes me think otherwise.
2016 Windjammer 3006WK
2010 Dodge Ram 2500, 4x4, Diesel, Front Hitch, Air Lift 5000 Rear Air Bags, (not really used, left over from our truck camper). Equalizer E4 1.4k/14k WD Hitch. TST 507 TPMS. Furrion FOS48TA Observation Camera. Garmin RV-760 GPS. Honda 2000i Genny, PI EMS-PT30C.
gectisme is offline   Reply With Quote
Old 08-01-2016, 08:26 AM   #34
I run my TPMS with the original rubber stems but use the metal sleeve that goes over the stem to reduce flex. I'm also running the non-flow thru sensors with the anti-theft caps removed. Very light weight that way compared to the flow through.
2016 Flagstaff 8529IKBS Diamond Package 5th Wheel
Ford F-Series SCREW 4x4
TST Tire Monitor - Sinemate 3500w Gen.
Nights Camped: '15 = 22'16 = 46
Old 08-01-2016, 09:05 AM   #35
Originally Posted by MarkyB View Post
Second tire has now failed...
Sitting at a rest area waiting on Coach Net..
For this very reason, we carry two spares for the trailer. For the TV, we have the 17" to get us moving and an unmounted 20" spare to prevent layovers as we had in post 17.
PenJoe is offline   Reply With Quote
Old 08-01-2016, 10:31 PM   #36
Dr-G's Avatar
Thanks - Now I can have piece of mind!
I bought a set of TST 507 (non-flow thru) sensors. I will see about removing the anti-theft cover and I will get metal valve stem covers for now.
Should be here Weds or Thurs this week for out upcoming trip.
'16 Cherokee Grey Wolf 26DBH
'13 Silverado 2500 HD - 6.0 Vortec / 3.73
Days Camped '16 - 12
Days Camped '17 - 0
Dr-G is offline   Reply With Quote
Old 08-02-2016, 11:18 PM   #37
MarkyB's Avatar
^^^^ this...
Ran the rubber stems on a few short trips, but had them swapped for metal and balanced the tires before this big trip.
16 F-250 Lariat 6.2 -- 16 Wildwood 31KQBTS
Nights Camped in 2016 : 25
Nights Camped in 2017 : 2
MarkyB is offline   Reply With Quote
Old 08-03-2016, 09:16 AM   #38
I run TST 507 on my 3500 Silverado with rubber stems and I have 84,000 miles on truck. Never a problem
2015 Cedar Creek 32RL
2012 Silverado 3500HD SRW
http://www.forestriverforums.com/for...ignhavefun.gif
spock123 is offline   Reply With Quote
Old 08-03-2016, 09:18 AM   #39
Oh yes I take the sensors off to balance the tires, my sensors don't have the locks on
Old 08-03-2016, 09:21 AM   #40
Why take them off? They don't weigh much, but heck, I'd leave them on.
Springerdad is offline   Reply With Quote
tire
