Old 08-03-2016, 10:37 AM   #41
Brother Les's Avatar
Originally Posted by Dr-G View Post
OP -
Now for a quick aside question regarding TPMS.
We just started RVing this year, our first 4 outings have been about 1 hour or less away.
This weekend we have a 3 1/2hr trip and was wanting a TPMS however, most say you need a metal valve stem. One out there says you don't but it is recommended.
OP did you have your valve stems swapped out?
Does anyone run with rubber valve stems? I would like the assurance for the trip. But don't really have the time this week to get the valve stems replaced.
Had a bubble on the side wall of an original tire (D rated) and took it in to be replaced. I asked for a metal valve stem and was told that the rim would not allow the bolt in metal type, but I was able to get a High Pressure stem that has the metal sleeve. I also went from the D-rated to the E-rated tire.
Brother Les
Old 08-03-2016, 10:50 AM   #42
wmtire's Avatar
Most likely, they didn't have the "correct" bolt in valve stem for your particular wheel application...but that doesn't mean that the rim won't allow all bolt in stems.
We have run into several applications on Forest River products/wheels where the valve stem hole is situated on the wheel flange in such a way that you cannot use a TR-416... but a TR-428 will work since it's built different.
I have a feeling they just didn't have in stock or experience with a TR-428 stem (since it's not as widely used) when telling you that.
TR428 1.50" Chrome Plated Brass Valve for Ford Trucks: Tire supplies, wheel weights, valve stems, patches, air chucks,TPMS
and here is a previous discussion we had on this scenario:
metal tire valve stems
2011 Flagstaff 831 RLBSS
Hypochondria is the only illness I don't have.
Old 08-03-2016, 10:17 PM   #43
Dr-G's Avatar
Originally Posted by spock123 View Post
Oh yes I take the sensors off to balance the tires, my sensors don't have the locks on
Originally Posted by Springerdad View Post
Why take them off? They don't weigh much, but heck, I'd leave them on.
Mine came today and I got them installed, being OCD and trying to get all the tire to 50# - well that's another story. The TST 507 was very easy to install.
I got the metal valve stem covers and removed the anti-theft covers but they are very lightweight so I put them back on. I did pick up some stick- on wheel weights. They say the sensors are 13.5g and the metal valve stem cover is only about 0.5g so I have 15 g wheel weights I can counter balance them if I want. I don't know if they were ever balanced as most trailer tires I don't think are balanced anyway as a rule.
2016 Cherokee Grey Wolf 26DBH
2013 Silverado 2500 HD - 6.0 Vortec / 3.73
Days Camped 2016 - 12
Days Planned - 12
Dr-G is offline   Reply With Quote
Old 08-04-2016, 08:29 AM   #44
You will get a smoother ride and better tire wear if all of your tires are balanced. If the tires are too far out of balance, they will get flat spots from pounding the pavement. Just look at other vehicles. When you see a tire not running smoothly, it is balance. Bad shocks will amplify the bounce. While balance tires, we have also found 2 tires over the years that were faulty. One was new and the other only had a few thousand miles. Those two tires would have failed on the road.
PenJoe is offline   Reply With Quote
Old 08-05-2016, 12:21 AM   #45
MarkyB's Avatar
Now I have five new Hercules E-rated tires.
Anybody hear of them?
16 F-250 Lariat 6.2 -- 16 Wildwood 31KQBTS
Nights Camped in 2016 : 25
MarkyB is offline   Reply With Quote
Old 08-09-2016, 05:36 PM   #46
Greetings my L/H rear driverside failed just like MarkyB.I lost almost 3/4 of the tread from the sidewall all the way across to the other sidewall.Causing well I just got a repair time of 2 weeks,maybe less.Wiped out all of the pulp wood and you can see the styraform now.So it must be fixed before we travel because of rain further damaging the bottom of the flooring.Does any one put 3/8-1/4 inch thick alumnium plate to prevent and is there a recall to replace these dangerous low speed rated tire on these chassis,I am under warranty and am thinking of asking FR to replace all these tires due to a to low of speed rating tire installed why 60 most hwy's are 75-80.It still blewout and we were going 60 the whole time,I save fuel,but everone pass's us.Engineering at FR really miss the tuna boat on that selection.........
2016 Forest River Heritage Glen 337BAR,towed with a 2015 Ram 2500 CTD,LoneStar Edition.
Bravo67 is offline   Reply With Quote
Old 08-10-2016, 04:50 PM   #47
I read some time ago on another forum where a guy installed some trailer fenders for somelike a utility trailor or car hauler under the body above the RV tires. Don't know how it worked out but that may be a resolution.
George Scott
2015 Salem Hemisphere Lite 272RLIS/ Prodigy P3
2006 Heartland BH 3400/Summer Home
2007 Dodge 2500 CDT QCSB/Blue Ox Sway Pro 1500lb WDH, Maxxis 8008 225 x 75 x15 LR E tires/J T Strongarms
Scotty is offline   Reply With Quote
Old 08-10-2016, 05:37 PM   #48
That's a great idea!
Springerdad is online now   Reply With Quote
Old 08-16-2016, 01:27 PM   #49
I forgot to post a picture of the tire,and the damage it cause.This looks like a tread seperation.From one side of side wall to the other side.Caused a hole in the flooring.How do they repair this.
Old 08-16-2016, 05:03 PM   #50
MarkyB's Avatar
Some more pics.
The inside of the first tire.
From left to right is the spare, ran about 800 miles.
The next two are front axle.
Last two are rear axle.
tire
