Old 09-25-2012, 08:56 PM   #1
john I
johnemt's Avatar
ideas? tire ware
i have a 2012 columbus 365RL 5th wheel and the other day i noticed that the rear tire on the right. the outside edge is showing heavy ware the center is good the inside is wareing but not as bad and the rear tire on the left is starting to ware the same but not as bad as right. only have 600 miles on them any one know what might be going on. trailer is not over loaded not even close to the GVWR. I did notices that the trailer is not level on the truck front is about 2 or 3 inches lower in the front then the back. don't know if that could cause this problem.
Thanks in advance
John I
2012 Columbus 365RL
2012 Dodge Ram 3500 6.7 cummins
1963 5'2" wife Sheri
johnemt is offline   Reply With Quote
Old 09-25-2012, 09:43 PM   #2
amxpress's Avatar
If the tire pressure is set to 80 psi and you're getting that kind of wear, you might have either a bent axle and/or an alignment problem. There are shops that can check the alignment of both axles. The way you describe the level of the trailer should not effect the tire wear you're experiencing.
Talk to you dealer about having the trailer's alignment checked.
2013 Palomino Columbus 320RS
2007 Dodge RAM 2500 6.7 Cummins
Reese 15K manual slider
Prodigy
M.I.L. in Florida for good!!
amxpress is offline   Reply With Quote
Old 09-25-2012, 09:49 PM   #3
If he is wearing the inside and outside but not the center, it is a low inflation type wear. Alignment or bent axle will wear one or the other, but not both inside and outside at the same time.
Old 09-26-2012, 08:05 AM   #4
Herk7769's Avatar
That camper's corners need to be weighed. He may very well be overloaded in that corner even with 80 PSI. The max wheel load determines the correct pressure for 100% tread contact with the ground. If he already has the max PSI, he is overloaded.
The attachment and a visit to a CAT scale that can weigh individual wheels will tell the tale.
How To Weigh | CAT Scale
HAM CALLSIGN - KC3FFW
Old 10-18-2012, 06:56 PM   #5
john I
johnemt's Avatar
update tire ware
found out today that the tire ware i had posted on my new columbus is from a bent axle. Now my dealer needs Forest Rivers blessing to have it replaced. i have owned 7 campers each with thier little issuses but this takes the cake.
You would have thought that this is such a safety issue that forriv would not even question it.
John I
2012 Columbus 365RL
Old 10-18-2012, 08:23 PM   #6
Dave_Monica's Avatar
Glad to hear that the problem has been determined.
If the front of the camper is 2 to 3 inches lower than the back, why don't you raise your hitch (or lower the pinbox) to get it level? One set of holes on the hitch should be about right.
That way the load may be better distributed over both axles and more clearance over the truck's bed rails is never bad.
Dave
Old 10-18-2012, 08:25 PM   #7
Iggy's Avatar
johnemt
Glad to hear that you found the answer quickly and your dealer is taking care of the axle.
I just sent you an PM with a personal question.
John I aka Iggy
Iggy is online now   Reply With Quote
Old 10-18-2012, 08:31 PM   #8
TURBS's Avatar
how do you know its not overloaded ? have you weighed it ?
TURBS
Old 10-19-2012, 07:22 PM   #9
john I
johnemt's Avatar
did not
No because i do not carry that much to bring it to capacity,and only carry half tank of water nothing in the holding tanks.
John I
2012 Columbus 365RL
