Old 12-20-2015, 09:22 PM   #11
Originally Posted by WSMFP View Post
Thanks for the replies everybody! It's definitely not the leveling jack. It's a triangle piece welded to the frame. There is one on each side at the rear of the camper. It's pushed up pretty good (almost flat against the frame). I'll post a pic as soon as I figure out how to. I'm just hoping it doesn't impact the functionality of the TT (other than the obvious -which I've learned my lesson).
We have a 2016 Puma Unleashed 351THSS and now both of ours are smashed flat...... After they both flattened out I no longer have clearance issues. LOL
I for the life of me do not understand why these things don't have drag wheels on the rear bumpers because at some point and time, everyone is going to drag the back of their camper......
gilwilliams101 is offline   Reply With Quote
Old 12-21-2015, 08:07 AM   #12
dcheatwood's Avatar
Yep. It did its job. Get you a couple of big tools and pull it back in shape. Stilson wrenchs may do it.
2013 Rockwood 8282WS
Reese Revolution Pin, Reese 16K
2008 Tundra Limited Double Cab 5.7L
Air Lift 5000 w/Wireless Air
dcheatwood is online now   Reply With Quote
Old 12-21-2015, 08:19 AM   #13
If you add Wheels remember that the Lowest part should NOT be greater than the V drag pcs.the Factory installed! If your Added Fix is Lower than Fac.it Will HIT Sooner,thus adding to your Problem! Youroo!!
Old 12-21-2015, 08:23 AM   #14
Brother Les's Avatar
If you have 'dragged' once, you will 'drag' many times over the years. My last unit that I had, I drug one of that bars completely off. I added drag wheels and they were on the cheap side with junk rubber wheels and they pulled off on the second 'drag'. Added steel drag wheels and the worked very well. Still be very aware when you go out of a sloped drive/ gas station and onto a level road way and your unit is 'too long' and will 'lift' in the back as you turn into the road. If you have room to manuviour, when pulling out, take the 'transision' at a slant and not 'head on'. Also, a few campground 'sites' are not level enough and you will also drap, backing in and pulling out. DO NOT put your drag wheels lower than the drag bars that are on your unit, you want them close to the same height. You will drag more often if lower and then comes the possiability of bending your frame from a hard hit/drags.
Brother Les
Old 12-21-2015, 09:30 AM   #15
TURBS's Avatar
I definitely would not put drag wheels on either!
Fix or replace what was there.
Old 12-21-2015, 09:56 AM   #16
An after thought, (Turbs post) Looking at a picture of the Wildwood, it does seem to have a ton of clearance under it and should (almost?) never drag (if I am looking at the correct picture) My former unit has a low clearance set up and would drag at some RXR tracks. No drag wheels should be needed on your unit.
Brother Les
Old 12-21-2015, 11:33 AM   #17
Replace with industrial grade casters
Harkerr is offline   Reply With Quote
Old 12-21-2015, 11:36 AM   #18
TURBS's Avatar
Do not install castors on an ultra lite trailer.
You'll bend the frame.
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
Old 12-21-2015, 12:47 PM   #19
B Mac
Like everyone says. "Curb Feelers" They make noise when you are getting in trouble.
bbbymac is offline   Reply With Quote
Old 12-21-2015, 12:51 PM   #20
PSUFan1's Avatar
I bent our triangle piece of metal and asked our dealer to see if they could repair it and they mentioned the only way to fix it was to heat the metal and bend it back but they didn't want to do that since my black tank sits right next to it. So I left it alone.
2012 Ford F-150 EB Crew FX4 3.73 gears
2012 Micro Lite 23lb
Tim & Tracy, Jennifer (15), Alyssa (10), our dog Jazy
2012 Ford F150 EB Crew FX4 3.73 gears
2017 Grand Design Imagine 2800BH
Previous: 2012 Flagstaff MicroLite 23LB
2006 GMC Envoy Denali V8 & 2005 GMC Envoy I6
PSUFan1 is offline   Reply With Quote
newbie
