Old 03-25-2012, 09:43 PM   #1
LKicklight's Avatar
Inflation decal
Just noticed this afternoon that on our new Crusader 270 RET, the inflation decal for the correct tire pressures is not correct. The tire and wheel combination shown is for a smaller tire and wheel than what is actually installed on the coach. We have 16" Optional Wheels and tires, so what would be the correct tire pressures?
ID:	11291   Click image for larger version
LKicklight is offline   Reply With Quote
Old 03-25-2012, 10:13 PM   #2
camper1999's Avatar
Check the side of the tire for the correct pressure. I never trust those stickers. I had a truck once where they put on the wrong one too.
2011 GMC 2500HD Diesel
Old 03-25-2012, 11:26 PM   #3
Webfoot
Do you run right at the number on the sidewall? My tires say 50psi cold, but I never run my tow vehicle at full pressure so wasn't sure on the trailer.
2012 Chevy Suburban 1500
2012 Surveyor SP-260
quackor is offline   Reply With Quote
Old 03-26-2012, 08:59 AM   #4
camper1999's Avatar
You should run your tires at max pressure to achieve the full weight carrying capacity. fill them when they are cold, have not been heated up by driving, to 50 psi. Your truck tires should be the same method.but if you have light truck tires you will fill the rear to 80psi and the front to 50 or 60psi
Old 03-26-2012, 09:57 AM   #5
LKicklight's Avatar
Sidewalls
The Sidewall Pressure says 80 PSI Cold Max....I assume that is what I should run..My friend that lives in Michigan received a new decal from Forest River to place on his Crusader 270..no doubt they will send me one...right now 80 psi is probably close to be correct..
LKicklight
Old 03-26-2012, 10:55 AM   #6
camper1999's Avatar
Yep if it says 80psi fill them up to that pressure
Old 03-26-2012, 11:29 AM   #7
Wanna Be Camper
SaskCampers's Avatar
That is not really true as LT tires come in LR C, D and E. The load range E tires are the only ones that are rated for 80psi
John & Deb
2011 Flagstaff V-Lite 30WRLS
Days Camped 2016: 3 2017: 0
Old 03-26-2012, 11:51 AM   #8
Webfoot
I believe my LT tires are D range and rated for 50 PSI. When Les Schwab put them on the rig they inflated them to 33. After I got the trailer they said they'd run them at 45 when towing.
Old 03-26-2012, 05:26 PM   #9
camper1999's Avatar
Sorry I should have mentioned my truck tires were load range e.
