Old 08-21-2016, 05:25 PM   #11
Ford Idaho's Avatar
Originally Posted by polishdon View Post
I got the veneer off, what a stupid, cheap set up.
I wonder how that worked out!.........
Glad you got the veneer off, now you need to replace the rest with real lug nuts.
Old 08-21-2016, 08:50 PM   #12
Originally Posted by wmtire View Post
I also need to emphasize strongly, you want to take care of this while it's still in your yard. You get out on the road and have a flat, you may be stuck because neither you nor roadside assistance can get the lug nuts off due to these messed up veneers and/or an underlying rounded off lug nut.
thanks for the info you've given in this thread,..... a few weeks ago I was greasing my wheel bearings and pulled the first wheel, thinking it was necessary to do the job right(it wasn't), ..... but on that wheel I did discover a loose "cap" on one of the nuts and believe it must have happened a few weeks before when I upgraded my tires and the tire shop used an air impact wrench to remove the wheels,.... with the info you've given here I now know what it is, how it happened and the importance of getting rid of those nuts while at home, than waiting and having to do it while on the road, ..... just completed an order for premium chromed, solid steel, one piece nuts from Amazon, .... again, thanks
fella10 is online now   Reply With Quote
Old 08-21-2016, 09:07 PM   #13
wmtire's Avatar
You are very welcome and glad it helped. As stated previously, I hate them.
2011 Flagstaff 831 RLBSS
Hypochondria is the only illness I don't have.
Old 08-21-2016, 09:55 PM   #14
fella10,
Do you have a link to the Amazon lug nuts?
I am not sure what size and thread pitch I need for my 23LB.
Big Johnny
2014 Chevy Silverado 1500
2014 Micro Lite 23LB
Are we having fun yet??
tipakajohn is offline   Reply With Quote
Old 08-21-2016, 10:16 PM   #15
Exlimey's Avatar
I'll be checking mine out before my next trip! Thanks for the heads up!
I had a Pontiac Vibe that had the cover/veneer. They got loose on the lug nut, probably from water freezing inside over the winter and causing them to balloon out. I bought a complete set of solid lug nuts with locks but found those to be too long. I tried to resize the veneers using a vice and it worked well enough to use them but I replaced them with a good aftermarket set anyway. New lug nuts from GM were prohibitively expensive!
Neil and Kimberli
2016 Chevrolet Silverado Z71 double cab
2016 Forest River Flagstaff 29KSWS Super Lite Saphire Package
Nights camped 2016 - 27
Exlimey is offline   Reply With Quote
Old 08-21-2016, 10:26 PM   #16
wmtire's Avatar
Another reminder, as I look at the wheels in the OP, when you get other lug nuts...you need to make sure the socket that fits the lug nuts will have room to fit over the lug nut and be able to still turn inside the wheel.
If you get a lug nut with a wider shank, then you may not have room to fit a socket or lug wrench over it.
Old 08-21-2016, 10:38 PM   #17
mlatter's Avatar
I just bought replacement nuts for mine as well since the originals were all cracking.
Link on amazon:
https://www.amazon.ca/gp/product/B00...?ie=UTF8&psc=1
These are one piece and are supposed to be the best.
2014 Cedar Creek 36CKTS Explorer
Xantrex Freedom SW3012 inverter/charger
2009 Silverado 2500HD Duramax Crew Cab short box
Demco Glide Ride pin box
Demco Hijacker Autoslide 18K hitch
mlatter is offline   Reply With Quote
Old 08-21-2016, 11:20 PM   #18
Originally Posted by tipakajohn View Post
fella10,
we have a Micro Lite 25KS,
I pulled one nut off and 1/2"-20 is stamped right on it, yours should be the same,......the link below is the ones I bought,... full set of 20 for $20,..... 100% positive reviews(some folks won't give 5 stars for anything, so I add 5 and 4 stars together to get percent of positive reviews)
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Old 08-23-2016, 09:16 PM   #19
Thanks so much for the reply. I ordered a set tonight.
Big Johnny
Old 08-23-2016, 09:36 PM   #20
acadianbob's Avatar
Originally Posted by JD and Beastlet View Post
I had the same crappy lug nuts on my F150 when I bought it used.
Yep, me too . . . .
http://i421.photobucket.com/albums/pp297/acadianbob/IMG_2757.jpg
2012 F150 FX4 Ecoboost, 2016 Surveyor 274BHS
2003 Yamaha FJR1300, Demco Premiere Slider
Red Green coffee mugs
acadianbob is online now   Reply With Quote
