Old 06-16-2015, 08:42 AM   #21
I have and use a Trailer-aid if I want only one wheel off the ground. Old Coots method for 2 wheels off the ground. My 5er has torsion axles.
2001 Ford F250 7.3l converted to F350 specs
2014 Flagstaff 8528RKWS
2 - 2006 model year Border Collies
Mtelkman is offline   Reply With Quote
Old 06-16-2015, 11:01 AM   #22
Originally Posted by lbrjet View Post
Fur, this method doesn't work with torsion axles, hence the discussion.
2010 F250 5.4L 3.73
2011 Flagstaff 831FKBSS
Equal-i-zer 4pt 12K
lbrjet, this method has worked on my last four trailers with torsion axles and it works just
fine on my 2014 Rockwood 5th wheel. The suspension travel, at least on all of mine was very limited and raising one wheel always lifted the other one along with it. Not sure about
trailers with that large 17 inch spacing between the tires, but it works on mine with standard
spacing.
furtrader is offline   Reply With Quote
Old 06-16-2015, 11:06 AM   #23
spacing.
Your method will lift one tire off the ground at a time, but is not good if you want to take both tires/wheels off the same side at the same time.
Old 06-18-2015, 07:52 PM   #24
Won't work on a unit with the 17" extended space.
George Scott
2015 Salem Hemisphere Lite 272RLIS/ Prodigy P3
2006 Heartland BH 3400/Summer Home
2007 Dodge 2500 CDT QCSB/Blue Ox Sway Pro 1500lb WDH, Maxxis 8008 225 x 75 x15 LR E tires/J T Strongarms
Scotty is offline   Reply With Quote
Old 06-19-2015, 12:44 PM   #25
Bossdriver's Avatar
Eidolon,
Also new to the 5th wheel world. I just recently did a re-grease of our trailer bearings. If you want to read what I did, I have a thread on Page 2 of this section. 'Super lube bearing system'. I made myself a set of boards w/different size pins from 12" - 5' to use for bearings,flat tire and leveling in a spot. I do have a 12 ton jack also if a little more is needed. Haven't done the two wheels at once yet. Still researching on this site and others. So far, thinking about two 8 ton jack stands on one side at a time. Hopefully I have a couple of years on these tires. Good luck in your research, there is a lot of good information on this site.
2012 Ford F350 XL,SD,CB,8',LongBed,6.2LGas,4.30 Axle,4X4,FX4,PlowPkg,SOF,HAC,HDC,SOF,E-LOKTracPos,Upfitters,Fog lights,AdvancTrak,SwayCntrl,5thWhl/GoosePrepPack,Reese Elite 5th wheel hitch. Towing 2014 Sabre Silhouette 311 RETS, Rear Entertainment, 3 Slides, Residential Shower,Euro Recliner,Relaxing Layout,Folding Bike Rack, 35'.
Bossdriver is offline   Reply With Quote
5th wheel, wheel
