Old 05-10-2013, 07:20 PM   #91
Originally Posted by jevanb View Post
I had to adjust my brake shoes last week and my 2.5 ton floor Jack is not enough
Either your jack is weak or you have a very heavy trailer.
Old 05-10-2013, 07:28 PM   #92
TURBS's Avatar
Yeah like 14 k heavy ! Lol
Old 05-10-2013, 07:50 PM   #93
Just right for a Chevy S-10.
Old 05-10-2013, 08:06 PM   #94
Now for the instructions on using a trouble light.
Ok do we plug it in first, or do we turn the switch on first?
Of all the things I've lost in my life the thing I miss the most is my mind!
prairiecamper is offline   Reply With Quote
Old 05-10-2013, 08:11 PM   #95
No, No, No, first you have to measure the distance from the outlet to the trailer to determine the correct size wire for the voltage drop. Then determine if the outlet is the correct amperage, after determining if it is wired in accordance with...
Old 05-10-2013, 08:17 PM   #96
Fulltime family RVer
I figured out the light. Mind you- there's no switch in it!
1 new tire is on. Spare is still on because I got chased inside by a storm.
Old 05-10-2013, 08:18 PM   #97
Oh, and the guys at the tire shop were amazingly cool for me showing up 8 minutes before they closed. Like remarkably so. And, the checkout counter guy simply told me to tip the guys instead of charging me.
Old 05-10-2013, 08:28 PM   #98
Don't forget to torque the lug nuts now and again after you pull it around 50-75 miles and repeat until the lug nuts do not move to guarantee the nuts are seated on alum wheels if you have them. Different than steel wheels which usually only require one torqueing.
Old 05-10-2013, 08:31 PM   #99
Denver, CO
garbonz's Avatar
Originally Posted by jeeplj8 View Post
not a huge fan of the harbor freight jacks, they are probably fine, but I don't feel good about them when I am working under stuff (BTW - never with just a jack, always with jackstands in place.)
Got a Sears nearby?
Craftsman Floor Jack Set: Tough, Stable and Always Ready at Sears
Buy Milwaukee floor jack and USA jacks for bottle jack. US made and high quality.
2017 Fuse 23T
garbonz is online now   Reply With Quote
Old 05-11-2013, 11:54 AM   #100
I have the standard equalizer on my Wildwood, so this would not apply to the OP. My wildwood weighs about 8000 loaded for camping.
I fabricated a saddle out of 1/4" steel to spread the load over the equalizer. This allows me to jack up one side completely without crawling under the trailer on a wet and rainy night to place a jack.
ID:	30149   Click image for larger version
ID:	30150   Click image for larger version
joshuajim is offline   Reply With Quote
