Old 05-12-2013, 09:28 PM   #111
Originally Posted by joshuajim View Post
I have the standard equalizer on my Wildwood, so this would not apply to the OP. My wildwood weighs about 8000 loaded for camping.
I fabricated a saddle out of 1/4" steel to spread the load over the equalizer. This allows me to jack up one side completely without crawling under the trailer on a wet and rainy night to place a jack.
Holy cow, that looks a bit scary!
I see the pictures did not copy, so one would have to go back a page to see what scares me.
bakken is offline   Reply With Quote
Old 05-12-2013, 09:31 PM   #112
I measured a Trailer Aid and made my own and it is 6-1/4" at the saddle low point. If it wasn't high enough, I'd just put a 2x under it.
Old 05-12-2013, 09:47 PM   #113
That's not a bad idea. How'd you go about building your own?
2012 Palomino Sabre 32BHTS
2008 GMC Sierra 2500 SLE 4x4 Duramax
clange is offline   Reply With Quote
Old 05-12-2013, 09:56 PM   #114
Took all the measurements and used 3 lengths of 2x8's and 2 1 x spacers and cut them out & glued and bolted them together. Will post pics tomorrow if CRS doesn't kick in again.
Old 05-12-2013, 10:15 PM   #115
PPST OGCDG
Frank-VA's Avatar
Here is a Picture of using plastic level blocks:
Frank- VA {:-{)
2004 4x4 Ford 6.0 PS, SCC, SB
2005 Wildcat 29 RLBS
Frank-VA is offline   Reply With Quote
Old 05-13-2013, 08:15 AM   #116
Look at it closer. There are tabs to keep the jack from moving perpendicular to the equalizer, the plate is set at a length that prevents front or back movement and the jack head is in a pocket.
The upward force is placed directly under the point where the two wheels would normally exert their force.
I believe it's the best place to jack.
joshuajim is offline   Reply With Quote
Old 05-13-2013, 12:31 PM   #117
Now, that's scary IMO!
Old 05-13-2013, 12:37 PM   #118
As promised. Notches in the sides are for the stow brackets on the back bumper just to the left and behind the spare tire.
ID:	30344   Click image for larger version
ID:	30345   Click image for larger version
ID:	30346   Click image for larger version
ID:	30347   Click image for larger version
Name:	Homemade Tire Changing Ramp.jpg
Old 05-14-2013, 06:12 AM   #119
jevanb's Avatar
nice I see myself making that in a few days, ????? how high you go on end and middle
2012 Wildcat 344QB
06 LBZ ,CC 4x
lots of mods
Superglide
jevanb is offline   Reply With Quote
Old 05-14-2013, 06:27 AM   #120
Bottom of tire saddle is 5-1/4", but don't remember the rest. Will have to get it off the trailer today and take some more pics with tapes.
I do know the radius of the saddle is 14-1/8" for my tires.
