Old 05-10-2013, 06:27 PM   #81
Wow! read all 80 posts. Best advise comes from post 36 except step 6 in post, and Turbs. A trolley floor jack lifts in an arc, and those little wheels on that jack won't roll on soft or uneven ground for approx 6 to 8 ". Chock wheels opposite side leave hooked up to tow vehicle use bottle jack 3 ton's is sufficient, one wheel at a time like post 36. Don't sweat the small stuff!
Of all the things I've lost in my life the thing I miss the most is my mind!
prairiecamper is offline   Reply With Quote
Old 05-10-2013, 06:27 PM   #82
PPST OGCDG
Frank-VA's Avatar
With the truck hooked to the camper, I used some 6x6x12 blocks and a 12 ton bottle jack. Set the jack on the blocks and set the jack just behind the rear spring hanger. I jacked up one side at the time. Put jack stands at u bolts, then I remove the two tires. on that side.
Frank- VA {:-{)
2004 4x4 Ford 6.0 PS, SCC, SB
2005 Wildcat 29 RLBS
Frank-VA is offline   Reply With Quote
Old 05-10-2013, 06:49 PM   #83
As the OP would be lifting under the axle, he would only have to jack it up maybe 3 inches. So that wouldn't be an issue.
bakken is offline   Reply With Quote
Old 05-10-2013, 06:56 PM   #84
Originally Posted by BarryD0706 View Post
Scary indeed. I have the Dexter Axle book right in front of me and it clearly says not to jack on the axle...any of them. Maybe you know more about this than the manufacturer does, but giving such advice publicly is "scary".
Just one quick question. You agreed with Turbs that jacking under the U-bolts was the way to go, but then post that I was wrong to suggest that?
Which is it?
Old 05-10-2013, 07:02 PM   #85
Fulltime family RVer
Ok, 2 tires off. Essentially I'm following Barry's and Ron'a advice...
The first tire was the original one that I took off due to the nail. Tire guys deemed it not repairable. That one came off last week and was removed using the ramp method. I had installed my spare where it came off last week.
The second tire was a good one. I bought a 3-ton floor jack and jacked the camper up by the axle (sears/craftsman). I only had a 2x4 for wood going between the axle and the jack and the wood crushed as I lifted. I lowered and removed the block and relifted directly by the jack's metal. I didn't like doing it, but I needed to make progress tonight.
The tires are being remounted and balanced now. I left the camper at home with the jack still supporting the axle. My 3-ton jack stand was too tall to fix under the axle. I may try putting it under the square metal box attached to the frame when I go to reinstall the wheels.
That's where I'm at. When I get home, I'll remount one of the tires tonight definitely. I hope to do both, but I'll likely be working in the dark.
ID:	30098   Click image for larger version
Old 05-10-2013, 07:03 PM   #86
I do believe we have hammered this one in the ground.
Old 05-10-2013, 07:11 PM   #87
Which is it?
Responded via PM to avoid meta-discussion here.
Old 05-10-2013, 07:13 PM   #88
YEA!! Congratulations! A new shade-tree mechanic is born!
Old 05-10-2013, 07:16 PM   #89
jevanb's Avatar
I had to adjust my brake shoes last week and my 2.5 ton floor Jack is not enough
2012 Wildcat 344QB
06 LBZ ,CC 4x
lots of mods
Superglide
jevanb is offline   Reply With Quote
Old 05-10-2013, 07:18 PM   #90
...but I'll likely be working in the dark.
Now for the instructions on using a trouble light.
