Old 05-10-2013, 12:40 PM   #21
Always Learning
Harbor Freight jacks:
4 ton bottle jack
3 ton floor jack
These?
Old 05-10-2013, 12:44 PM   #22
daydreaming about camping
jeeplj8's Avatar
not a huge fan of the harbor freight jacks, they are probably fine, but I don't feel good about them when I am working under stuff (BTW - never with just a jack, always with jackstands in place.)
Got a Sears nearby?
Craftsman Floor Jack Set: Tough, Stable and Always Ready at Sears
2013 Coachmen Freedom Express 320BHDS pulled by a 2005 F250 King Ranch CC
A rainy day camping is better than a sunny day at work.
jeeplj8 is offline   Reply With Quote
Old 05-10-2013, 12:46 PM   #23
4 ton bottle jack
3 ton floor jack
These?
Both, floor jack for home and bottle jack in camper for emergencies.
Old 05-10-2013, 12:48 PM   #24
Always Learning
Understandable about Harbor Freight and their inexpensiveness. I figure for the so few times that they'd be used, it could be fine. But, I actually have a Sears like 3 minutes from my house...
Old 05-10-2013, 12:48 PM   #25
TURBS's Avatar
X2 !
So you gone yet ?
Old 05-10-2013, 12:51 PM   #26
Always Learning
Originally Posted by f1100turbo View Post
X2 !
So you gone yet ?
OldCoot and Turbs.. that makes sense. Just mo money to spend.
Any reason why I can't do the bottle jack here at home (considering I've been a car owner for 17 years and a home owner for 12 years and have never needed a jack before)?
Old 05-10-2013, 12:53 PM   #27
Rugged Brown's Avatar
Take pics so this can be archived for future reference. I changed a blown tire on the freeway with a 3 ton Canadian Tire floor jack in less 5 minutes. Tracker trailers whizzing by 3 feet from my ankles was a little unnerving, hence the rush to change the tire.
Terry/Bernadette
Lily the Yorkie
2019 Dodge Ram Sport 1500
2019 FR Vibe 28RL
Rugged Brown is offline   Reply With Quote
Old 05-10-2013, 12:56 PM   #28
TURBS's Avatar
Bottle jack would be fine.
Center it good an jack.
Why u still here ?
Old 05-10-2013, 12:56 PM   #29
TURBS's Avatar
Pictures ? I'm thinking you tube video!
Old 05-10-2013, 12:57 PM   #30
Engineer of Crazy Train
ChooChooMan74's Avatar
I would do the bottle jack. For once a year a home to take your hubs off for inspection and keep it in the unit for on road emergencies.
TV - 2015 Ram Truck EcoDiesel
TT - 2015 Rockwood Roo 183 (SOLD due to 2 years off work)
Locomotive Engineer
Nights Camping --- 2015 - 19 Camped | Winterized -- 2014 -18
Come read my Camping Blogs
ChooChooMan74 is offline   Reply With Quote
Old 05-10-2013, 12:58 PM   #31
Phat Phrog Stunt Crew
awwall's Avatar
Did you happen to read this thread? For what it is worth, when I had a fiver, I jacked under the axles on several occasions. I KNOW, everything says not to do it. I jacked as close the wheel as I could get, while leaving room for a jack-stand between the 2. I did a complete brake change-out and replaced all bearing using this method. I never experienced any problem with coach afterwards.
http://www.forestriverforums.com/for...ler-17027.html
Wayne & Susan Biloxi,Ms
2012 GeorgeTown 351DS...2015 Ford Focus/Brake Buddy
FROG Member
awwall is offline   Reply With Quote
Old 05-10-2013, 12:58 PM   #32
Would go with the Sears kit and buy a bottle jack. As I stated before, the floor jack at home, bottle jack for trailer.
Floor jack is much safer PERIOD!
Old 05-10-2013, 12:59 PM   #33
Always Learning
It would make it a lot easier for the medical examiner...
Old 05-10-2013, 01:00 PM   #34
Always Learning
I had. Unfortunately in my ignorance, I wasn't sure how it all applied to me + my situation.
Old 05-10-2013, 01:02 PM   #35
Always Learning
Dang it, OC. You know my hot button... it's safer because there's more area for the lifting. Correct?
Hmm.. you might have just sold me on the floor jack.
Old 05-10-2013, 01:02 PM   #36
Here's my two cents.
  1. Taking advice on how to do something that could get you killed off of the internet is a very questionable activity.
  2. If those are Dexter axles, the book specifically says not to jack on them. Having said that, I agree with Turbs that there is no where to jack on your frame (and don't know that the frame could support a single-point lift with that much force either).
  3. Turbs has the same RV and experience, so do as he says and put the jack only under where the u-bolts are.
  4. I wouldn't even try to use a jack-stand (because trying to get that on the u-bolts at the same time as the jack is going to be difficult). Jack up one wheel, remove the tire, put the spare on that wheel and lower it. Jack up the other wheel, take the tire off, leave the jack in place and go to the tire store. (It the jack sags a little, it's OK since you've still got the spare on the other wheel to support the trailer.)
  5. A floor jack might be nice, but one with enough tonnage to support half of your trailer will be expensive and, as you said, you can't use it anywhere else. Go to either Sears or a reputable auto-parts store and buy no less than an 6-ton jack. (The price doesn't go up that much for higher power and you want to make sure you have enough. Mine is 10-ton. I think Lou's is 12-ton.)
  6. That block of wood is only to spread the force around the area of those u-bolts... not to spread the weight onto the axle tube so it doesn't need to be big and it doesn't matter which direction you put it.
Old 05-10-2013, 01:03 PM   #37
TURBS's Avatar
dang it, oc. You know my hot button... It's safer because there's more area for the lifting. Correct?
Hmm.. You might have just sold me on the floor jack.
yes !
Old 05-10-2013, 01:04 PM   #38
awwall's Avatar
Just wanted to say I support the bottle jack. Lots cheaper and easier to store. If you go this way, be sure to make you wood chocks to go under them to get you close to whatever you are going to jack. Bottle jacks are usually limited to a few inches of lift.
FROG Member
Old 05-10-2013, 01:05 PM   #39
TURBS's Avatar
[*]Taking advice on how to do something that could get you killed off of the internet is a very questionable activity.[*]If those are Dexter axles, the book specifically says not to jack on them. Having said that, I agree with Turbs that there is no where to jack on your frame (and don't know that the frame could support a single-point lift with that much force either).[*]Turbs has the same RV and experience, so do as he says and put the jack only under where the u-bolts are.[*]I wouldn't even try to use a jack-stand (because trying to get that on the u-bolts at the same time as the jack is going to be difficult). Jack up one wheel, remove the tire, put the spare on that wheel and lower it. Jack up the other wheel, take the tire off, leave the jack in place and go to the tire store. (It the jack sags a little, it's OK since you've still got the spare on the other wheel to support the trailer.)[*]A floor jack might be nice, but one with enough tonnage to support half of your trailer will be expensive and, as you said, you can't use it anywhere else. Go to either Sears or a reputable auto-parts store and buy no less than an 6-ton jack. (The price doesn't go up that much for higher power and you want to make sure you have enough. Mine is 10-ton. I think Lou's is 12-ton.)[*]That block of wood is only to spread the force around the area of those u-bolts... not to spread the weight onto the axle tube so it doesn't need to be big and it doesn't matter which direction you put it.
Couldn't have said it better.
Old 05-10-2013, 01:05 PM   #40
Old Enough to Know Better
gasman6674's Avatar
I used a 4 ton Sears floor jack when I did my wheel bearings and it picked my rig up fine jacking the frame in front of the axle. I used a piece of 4x4 to space the jack. My only issue was I had to lift it pretty high to get both tires off the ground. From now on I will lift it under the spring. I already carry a small floor jack in my rig as it doesnt have a jack. it is more than capable of lifting one wheel at a time far enough to change a tire. Bottle jacks a great and nice and compact but you need to be dead nutz centered and level or they might tip thats why I dont care for them.
Jim & Debbie England
Do you have Gas? 2015 F350 6.2L CCLB DRW 4.30 axle.
2020 Keystone Cougar 364BHL ,Gone 2012 Yellowstone Ridgeline 34RLT Fifth Wheel
gasman6674 is offline   Reply With Quote
