Old 02-25-2015, 07:54 PM   #1
member
Kenda 14" d rated tires
These are the only D rated tires I could find. Has anyone ever used or heard anything about these tires?? I would like to up grade to a D but wonder if I would be better off with a well known brand like GY Marathons or Maxis 8008 in a C load?? Any help or opinion's would be great.
Karrier ST205/75R14 Radial Trailer Tire - Load Range D Kenda Tires and Wheels AM10235
2016 Rockwood 8310SS Signature Ultralight
2017 F 250 6.2 gas 4.30 8' bed
HIDE OUT is offline   Reply With Quote
Old 02-25-2015, 08:25 PM   #2
Platokidd's Avatar
Power King Towmax or GY Marathons are probably the best choices. But Im no tire expert.
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
nights of camping
2017-67 / 16-92 / 15-73 / 14-60 / 13-33
Seasonal
Old 02-25-2015, 08:48 PM   #3
Oklahoma Proud
MillerTime's Avatar
I've never had kendas or maxis for trailer tires, and im a hater of anything goodyear personally.
I use to race quads when i was younger, and the Kenda's and Maxis' tires were 2 of 3 of the best tires out there and most of the big boys ran those top three. I had all three brands, maxis was my favorite with kenda a close second and the other brand was wayyyy down my personal list.
If i was buying new st tires and either of those were available and not too cost prohibitive, i would give either of them a shot!!
Good luck!!
Old 02-25-2015, 08:57 PM   #4
dannyabear's Avatar
No, get the Kumho 857 or Hankook RA08; 99 mph and 8ply D rated and not made in China
Danny & Darlene
2002 Silverado 1500HD
2014 Rockwood 2703WS 'Emerald Pkg'
Days camped 2015=42 2014=48 2013=41 2012=47 2011=18
dannyabear is offline   Reply With Quote
Old 02-25-2015, 09:05 PM   #5
Oklahoma Proud
MillerTime's Avatar
Both those brands have served me well on my trucks in the past!
Again haven't used them on light trailers though. I've had hankooks on a big rig before with good luck.
Old 02-26-2015, 12:16 PM   #6
rsdata's Avatar
Have you looked for tires and user ratings on www.tirerack dot com? I bought some 8 ply Kenda tires from them 3 years ago based on info i got there. So far so good.
2014 Shamrock 183
2014 RAM 1500 Bighorn Crew Cab, HEMI, 3.21 gears, 8 Spd, 4X4
Old 02-26-2015, 01:04 PM   #7
I have the same Kenda tires on my popup. Only have had them a year and 24000 miles on them but have had not problems. Got them from etrailer. I also replaced the wheels as they carry a higher PSI rating.
cabranch47
2009 Flagstaff HW27SC (NTU 2014)
1999 Ford F150
cabranch47 is offline   Reply With Quote
Old 02-26-2015, 01:16 PM   #8
I have the Kumho 857's on my 6501 vibe. They are working very well. I have about 3000 miles so far including 100 mile of logging roads last summer and they still look new. Much less sidewall movement compared to the OE tires. I had them balanced and metal valve stems so I could rum them at 65 PSI (max is 69).
Ontario
Vibe 6501
1 Prospector Canoe
2 Mtn. Bikes
4 Hiking Boots
Happy Vibe is offline   Reply With Quote
Old 02-26-2015, 03:14 PM   #9
NV245's Avatar
I had a 2003 Cardinal 5th wheel with Kenda tires. In 2007 the rear off door side tire exploded and did almost $3000 damage to the trailer on a trip to Disney World. Put on the full size spare, replaced the tire and continued to Disney. On the way back, the front tire on the same side let loose, and I was glad that I had purchased a new tire for the spare. After getting home, I noticed that the two door side tires had baseball sized bulges on them. The build dates showed the tires were built in late 2002. The original spare was cracked in the center of the tread. I called Kenda, the reply was no help. 5 year old tires should not have gone bad like that. They got replaced with Uniroyals.
NV245 is offline   Reply With Quote
Old 02-26-2015, 03:22 PM   #10
member
Thanks everyone for all the info and experiences with the Kenda tires guess Ill stick to the good old marathons in the C range
tire, tires
